New Carquest EP 20k Filter C&P
Forgot to mention. Cartridge filters are also available. They had one for my Pentastar.
I also called PG for efficiency but techline was closed. Eastern time….
Is the black seal gasket silicon ? Looks to be nitrile . You'd think a $16.99 oil filter would get the orange silicon gasket like that of the CARQUEST Premium @ $9.99 .
  • Like
Reactions: GW.
I may actually use one of these if I ever use up my Baldwin B33's! The biggest difference here is my Baldwins only filter out the bird nests and small pebbles because that is the Toyota specs. I would guess you won't be disappointed with the media on that filter once you find it. I doubt they would build a filter of such quality and use a cheap media. Just sayin.
Tested shipping with a 15% discount code:
Minimum order $35. This is for 3 filters
Use filters with nitrile . Currently O.E.M. Hyundai / Kia . I use CALIFORNIA Olive Ranch 100% California Extra Virgin olive oil for the seal gasket :D . You'd expect a silicon gasket at the cost of $16.99 . 🤷‍♂️
Here's a chart of the properties of various rubber compounds. You'll see that nitrile, especially HNBR, is superior in every way to silicone in both the physical and chemical properties that are important to an oil filter base gasket. Oh, yea, the HNBR is also more expensive than silicone.
An argument can be made that the wider temperature range of silicone would be better for the ADBV. On the other hand, we've seen silicone ADBVs, with its poor physical properties, damaged by the inlet holes.
https://mykin.com/rubber-properties
Ed
