So, I found the Service Interval sheets, and Fluid requirment sheets.
For the PS it says not to use ATF. I really don't like the idea of forking out $15 for 500ml of fluid when it takes 1.5-2.0L of the stuff.
So in flushed out the burnt, dead, stinky, filthy factory fill PS and put in some Maxlife ATF, but that was before I found the little caption that warns of ATF use.
The steering is also much more responsive, the pump is silent, and so far there are no ill side-effects. I just want to be sure though.
