CO2 ? Dissolved oxygen ? Oh my God , this is getting crazy . How about " Top tier water " ?
CO2 ? Dissolved oxygen ? Oh my God , this is getting crazy . How about " Top tier water " ?![]()
This is correct. You can use a scoop for beans but you need to weigh the scoop and beans and than determine the proper level of beans per scoop per cup.You want one that pumps the water when it reaches the proper temperature. The Ninja and some other similar ones do that. MrCoffee and ones like it do not get the temperature right.
Also grinding your beans will make a big difference.
Lastly weighing the coffee is better than measuring it.
Yes, some take their coffee seriously and will do anything to achieve the "perfect cup". I found using a Brita pitcher is good enough for me but out of curiosity I tried a water treatment called Third Wave but didn't like it.CO2 ? Dissolved oxygen ? Oh my God , this is getting crazy . How about " Top tier water " ?![]()
Not all of them, the one I have and the home models hold water that is always up to temp when you add water it forces the hot water through the machine when you close the lid. You only turn the warming plate on or off not the machine itself. It is very rare to hear it heating water.
The only time it takes longer to heat up is when you first fill the machine.
The Bunn puts the rest of these POS to shame, through the years I have used many many of these things and there is no comparison for a real coffee drinker.
That is what the SCA recommended coffee maker list is for.. they do make better coffee.I am not one who won’t spend the money if the above Bunn coffee maker made a better cup I’d be all over it. We have the above suggested Bunn at the shop because it brews a fast pot not because it brews a better cup I and many others do not believe it does.
They are... they do... they will...If I ever went with a drip again, I'd really like to try a Technivorm Moccamaster. They are pricey but are supposed to work very well and last a long time.
The best cup of coffee I stumbled up on was when I used distilled water for the heck of it.Makes a great pot of coffee without the chlorine and whatever is in tap water.
Yes, can second this. The Technivorm is worth every penny. Have had one for a decade or so, it is great. We mainly use the espresso machine, but when we make drip coffee it is with the Moccamaster.They are... they do... they will...
That's not how they work - Trav explained it already too. They always have hot water in their reservoir, ready to go. When you first get a Bunn like this, you fill the internal reservoir - it takes 1-2 full carafes of water to do this. Then you turn it on which is only for the reservoir heater. When you want to make coffee, you add the amount you want to make which it "measures" and pulls that same amount from the heated water reservoir. Once you close the lid, it immediately starts making coffee. I make (6) cups normally and it's ready in 2-3 minutes.
What's an MJB ?If you are drinking regular ground coffee from MJB or Folgers or whoever then you won’t notice this as their coffee is lower grade.
