Got a new ranger xl work truck with spilt bench and radio as I have a lot of destruction an construction to do on my log cabin all this year - and the Yaris was just getting "long in the tooth" after being flogged on my grinding commute for 3 years. Been pretty pleased with the ranger over the past couple days, but I am being the usual nervous nellie concerning breaking in the new truck. Well, coming home today over a few bumps i started hearing and feeling some odd looseness in the front that wasnt there previously - in fact i was impressed with how tight the vehicle was. When I got the beast home in the drive way I steered the front wheels over so i could get a peek at the sway bar links and shock mounting bolts, etc. Most things looked and felt good to the rubber mallet, then I saw the front cab mount on the right side was somewhat crooked and the donut was "expanded" compared to the one on the driver's side. I reached up to the top mounting bolt and it was loose! I took the bottom donut off and it was full of water and the through-bolt was rusting! Well, after cussing up a storm, I finally cobbled together some extensions and tools and a socket to tighten the 18mm top nut, and center the top washer so no water could get in down the assembly into the rubber doughnut hole.
This whole (minor?) quality episode has me worried about what else they messed up. I spent an hour pouring over the thing and only found a couple rub points for the radiator coolant reservoir tank hose that I will beef up, and a hard polymer(nylon?) spaghetti vacuum pipe that was already being worn through by the sharp milled edge of the AC unit. Maybe this will be it? I am hoping. On the good side, I like that I got a nice metallic charcoal paint instead of white - I am tired of looking like the meter reader or the National Grid surveyor
