I don't know. I think the Popular Mechanics articles was publish in April 2025. The Troy Built mower in their test was a 2008 model. So I assume that means their mower test was done from 2008-18. The article covers more than just the mower extended time OCI test. It also covers the same topic for Ferraris and other super cars and cars in general.Are these Check and Add mowers shipped dry like most other mowers?
I'm semi retired and work from home. I have my groceries delivered. My car is only used to go to dental and medical appointments. My cousin, neighbor, and caregiver take turns driving me in my car to appointments. When I go out in my neighborhood I drive my mobility scooter (when it's not raining).Why have a car that just sits in the garage looking pretty? Idk if it’s an income difference but I don’t understand it
Fair enough, my apologiesm semi retired and work from home. I have my groceries delivered. My car is only used to go to dental and medical appointments. My cousin, neighbor, and caregiver take turns driving me in my car to appointments. When I go out in my neighborhood I drive my mobility scooter (when it's not raining).
Yes we can, I'll snag some this weekend.Can we get a dipstick pic on the Prius?
I know colour is “not an indicator of oil condition” but it’s still interesting regardlessYes we can, I'll snag some this weekend.
Tell you what, that guy that told you it’s not a safety concern as of right now?? I’d get a second opinion on that thing because if I’m not mistaken, where that hole is the lower control arm is bolted pretty close to the area. If I remember. And if that’s the case you could potentially have an issue. I’d have someone look at it and see if they could at the very least weld a plate there for reinforcement.The plan now is to do whatever I can to slow the rust down to try to buy a couple more years out of it. Any ideas in addition to the POR-15 are welcomed. I topped it off ~2 weeks ago and am at 265,200 miles. Top off was a half quart, not significant change from before the we started this journey.
I went out and looked again and it appears you are correct. They seemed to think it was ok. I'll get a second opinion here locally for peace of mind. Thanks for that input.Tell you what, that guy that told you it’s not a safety concern as of right now?? I’d get a second opinion on that thing because if I’m not mistaken, where that hole is the lower control arm is bolted pretty close to the area. If I remember. And if that’s the case you could potentially have an issue. I’d have someone look at it and see if they could at the very least weld a plate there for reinforcement.
But I hope I’m wrong because I love your experiment and I want to see you get another two years out of this thing safely. As for the rust containment, it’s pretty darn hard when it’s gotten that bad. Anything will help. Fluid film, NH oil undercoating, grease, oil, POR-15. I’d go with the very cheapest option possible…a mixture of grease and penetration oil you have laying around and just smear/spray it all up in there.
~33,500. I have been changing the filter every 10k and topping off, roughly 1 quart total added per year, give or take. As others have said and I'm beginning to believe it, this isn't really that big of a challenge for this type of engine.Doesn't look too black... how many miles since your experiment began? Have you been tracking how many new quarts you've added?
Haven't done any yet but I keep intending to. Fail on my part.I'd like to see you use an extended OCI filter that's rated for 15K, 20K, or 25K. Then only change the filter at its recommended OCI.
How often are you doing used oil analysis? Are you going to post them?
Without the OCIs we're only guessing how well the oil is holding up. It'd be nice to know. I suggest doing your first UOA when the oil starts to look black. You're not there yet. At this point it still looks clean, which is good enough for me. So you haven't failed. You're test is still good.Haven't done any yet but I keep intending to. Fail on my part.
Supertech filters from Walmart. I have a big stash left that I bought during COVID.Without the OCIs we're only guessing how well the oil is holding up. It'd be nice to know. I suggest doing your first UOA when the oil starts to look black. You're not there yet. At this point it still looks clean, which is good enough for me. So you haven't failed. You're test is still good.
The filter matters. What filter are you using?
Not the best filter, but maybe good enough. For what you're doing, I wish you were using NAPA Gold because it filters 23 microns @ 99% and is designed for extended OCI with silicon gasket and anti drainback valve. Napa Gold has a coil spring, which is a more reliable design. Supertech filters have a leaf spring, which is a less reliable design.Supertech filters from Walmart. I have a big stash left that I bought during COVID.
