I'm posting this for my friend. He has a 2005 Chevy 2500HD 4X4 with noisy brakes.
He's tried everything he can think of and still they make all kinds of racket.
The problem: Brakes are quiet for a couple of months, then they start to squeal, then the pads rattle in their brackets making even more noise.
So far he's basically replaced everything 3 times. First was a shop replacing calipers, brackets, pads and turned the rotors. Second time, the shop re-did the work in an attempt to fix it. Third time, he took matters into his own hands. He replaced everything again, including new rotors. He is using Wagner Thermo Quiet pads and has tried lubes and and sound deadening goo as well as none at all. The abutment clips are in place as well.
Basically they start quiet, then they squeal, then finally they become so loose in the brackets, that when he hits a bump, the pads will bounce/rattle really bad. He even showed me how loose they are by taking a screw driver and reaching in through the rim and moving them up and down.
Has anyone run into this before?
