Do front and rear brake rotors need to be the same brand?
USA
For context: I own a 130k mi. 2013 FWD Kia Sportage 2.0L T-GDI and am struggling on a first time brake job finding parts. The goal is new, quiet, and long lasting pads and rotors that fit. My rear rotors are stock, rear pads replaced @ 100k, front rotors and pads replaced @ 83k. The rotors are glazed and pads are low, 3mm front and 5mm rear from what they told me.
I got into manual repairs around last September because I felt price gouged by all the dealers around me. $650 for a valve cover gasket job, $1574 for all new brakes (both of which I declined and am now attempting myself). I changed the oil with OEM filter+Valvoline Restore and Protect myself to hopefully keep this engine in tip top shape. Also repaired the failing driver window motor+switch, and soon my loose spoiler once the 3M VHB arrives.
I was recommended rockauto and partsgeeks to find compatible brakes, but brands I was recommended like Bosch Quietcast and Advics for rotors, and for the brake pads I plan on using AKEBONO ACT1398 for $45 in rear, and AKEBONO ACT1295 for $46 in front unless there are better options im not seeing.
Problem is, I can't find Front Rotors! ADVICS R6R239U for $44/per or BOSCH 28011488 QuietCast for $34/per are both for the rear, but nothing for the fronts? I was looking for advice on whether differently branded F/R rotors was looked down upon or if I can find the right brakes somewhere else?
Just looked up your vehicle here in Canada from max brakes I can get four rotors and pads starting at $227.10 plus tax
The only requirement is that all rotors need to be round.....
Well, straight is nice too!
Can tire has front rotors and kits. I don't worry about having the same brake pads front to back either, although you should probably get something similar on both ends, not mixing good performance brakes with white box specials.
I just get OE or OE+ from can tire most of the time.
Is this FWD or AWD?
There are raybestos element 3 rotors available for front and rear.
I'd probably use the bosch on the back and element 3 on the front.
If you dont like raybestos element 3, Dynamic friction for the front
Akebono pads are usually good
there are at least 5 different pads on rockauto I would use with no worries.
I have to say if you had to ask this question, do you know enough to do a quality brake job? its not hard but its very important to get it right.
ive got a friend who works on cars a lot who is going to assist
which would produce the least dust and noise?
It looks like there are even fewer for the front than yesterday. The elements 3 were good a few years ago but are total crap today, the quality took a nose dive, the parent company is bankrupt.
I would probably try the Centric for the front rotors
