Until you have to deal with their dust and eating rotors. I had them and love them except for the dust (even on steel wheels!!!!) and rotor chew.The EBC Ultimax2 is a great daily driver pad![]()
I use ATE SL.6 or Bosch ESI6 in Japanese cars all the time. They’re chemically similar to OEM Japanese fluid but brake fluid doesn’t affect pedal feel(if everything is bled right and the base brake system - calipers/wheel cylinders and master cylinder are in working order, if you have drum brakes those also need to be adjusted properly). The only brake system part that cares about viscosity is the ABS/ESP modulator. IIRC, DOT 3/4 is a 1500mm2/second fluid, DOT 5.1 is <1000mm2/second, DOT4LV is <700mm2/second. To the foot, it’s nothing. To a computer, it’s something.I've transitioned my vehicles and the ones I look after off DOT3, DOT3 HT, DOT4 and DOT4 LV.
DOT5.1 just works better in my experience, it's not as water hungry as DOT3, lubes better and when it's -40 outside, it doesn't result in as sluggish pedal like I've had with DOT4.
I don’t see why not if the price is right.Any reason not to run DOT 5.1? I’m going to bleed brakes on the Tempest when it comes out of winter storage. Also, time to clean front discs. Thinking of going ceramic or semi-metallic. Current pads came with conversion kit and dust has not been an issue but maybe I can’t leave anything alone. This whole thread has been enlightening.
Bosch 3/4/5.1 $10 or so at RA for a quart if I buy with other stuff I need.I don’t see why not if the price is right.
Easy. Amazon has it on Prime as well, paid $15 for a liter.Bosch 3/4/5.1 $10 or so at RA for a quart if I buy with other stuff I need.
Exactly. Soft pedals are caused by hydraulic issues. You can have a firm brake pedal, but the car stops poorly. The latter is a pad/rotor issue.I would try to flush the brakes out before condemning the brake pads. Also make sure the are no leaks from the master cylinder/wheel cylinders.
Or an assist issue of course, ie not-power brakesExactly. Soft pedals are caused by hydraulic issues. You can have a firm brake pedal, but the car stops poorly. The latter is a pad/rotor issue.
I am a long time user of PowerStop I like em don’t get me wrong what I don’t like is even though they match the friction coefficient of the factory pads on my vehicle they do their own thing with friction materials not matching the OE friction material. As in ceramic-semi metallic-hybrid powerstop is ceramic with fillers or carbon ceramic plus fillers. My next pad purchase I’m venturing out to a pad manufacturer that labels OE specific friction material. I did once use BOSCH Blues for rears with O’Reilly rotors and had nice results.Centric semi metallics. Slap a set on. I used to have issues with what i thought was warping…..it was ceramic pads depositing material on the rotor face. Was in a pinch and I threw a set of 15$ metallics on one day to buy sometime till i could service it properly. My brake “warp” went away in 300 miles. Eventually did front and rear rotors and semi metallic pads. It was better than ever.
—Wagner thermo quiets were no bueno for me. Power stop were not great either. Both wagners and power stop were noisy and wore quickly ymmv.
You sound like you know your brakes there, have you used TRW or ADVICS also what do you think about DFC they're fairly new to the the aftermarket (I think?) Dynamic Friction Company they're 4000 series Hybrid pads seem interesting along with their ceramic 5000's. I hate to be one of those content readers cause a company has phenomenal marketing but the parts ain't worth a stinky tuna can.The only way you will get OE specific friction material is from the dealer, unless you have a Euro car
Even Akebono's aftermarket pads are not the same as OE even when Akebono is the OE supplier. However, there is nothing wrong with aftermarket Akebono pads.
EBC isn't an OE supplier, but the EBC Ultimax2 pads (Blackstuff) are awesome and the best daily driver pads I have come across.
Most brake pads changed their formulas recently to remove copper, as it is being banned in brake pads.
Nissan Rogue 2nd Gen 14-20. I watch DFC's YouTube channel they're founder and marketing guru talk a lot about how their company image is to provide OE matched friction material to each particular vehicle.I haven't used TRW or Advics pads, but either should serve you well. I mostly use EBC Blackstuff and Akebono pads.
The DFC pads should be ok. I would guess they're most likely similar to Powerstop in the range they offer
If you buy them from Rock Auto, just get whatever pads ship from the same warehouse as the coated rotors you select
What kind of car do you have?
I have around 10,000 miles on the PowerStop OE kit with Z17 pads front and rear I am considering just doing a pad slap on the front the rotors are in pristine condition. For now I would just leave the rears with the Z17 pads. I could scotch brite the front rotors make them more friendly to accept new friction material re-lube the sliders clean things up and drive on. The Z17s have been super easy on the rotors.They make many different pads. The DFC 5000 series claims to be the OE match. It might be worth trying if it's a good price. Other good options include Akebono, Advics, and Bosch Quietcast.
Rock Auto has DFC pad and rotor kits that include the coated rotors and 5000 series pads![]()
