Wondering what kind of oil and/or additives I could use to minimize oil burning in my 86 caprice with the 305 engine. The motor has been run out of oil a couple times, run low on oil a lot, run overfull on oil, run too long on OCI's and also overheated a couple times. It's currently using about 1qt every 300-400 miles with 10w30. It leaks a lot, but also has visible blue smoke under medium to hard acceleration. Compression is still around 155-160psi every cylinder but obviously the only way I'm going to help the problem is some really thick oil. What would you recommend? I currently am due for an oil change and I'm putting Rotella 15w40 in, but once the weather warms up a bit I'm thinking of 20w50 or heavier or maybe an additive that will thicken it up a lot too. It hasn't been really cold lately but it did get below 0F the last couple mornings so not sure how cold i can go and still start, the car has no block heater. I need to drive this car another 3 months or so at least.
