Nano-based lubricant from Millers Oils
Outrageous claims for sure.
Mighty skeptical here, but open minded.
I would volunteer to be a beta tester! My fleet can use all the help it can get!
Understand the skepticism, but when you delve through it all, it isn't as outrageous as it may first seem. Remember that frictional losses consume about 15-20% of power developed at WOT - that FMEP (friction mean effective pressure) is more or less constant relative to throttle, so at lighter loads, itwill be more. So there certainly is opportunity for a reduction in friction in some portions of the engine to give significant benefit. But this is also just oil we are talking about, so significant will mean different things to different people.
Please check out the links. All of hte dyno tests were done by external entities not affiliated with Millers. You may not recognize some of them, but a lot of contact infomatoin is included if you want to call the places and ask them. The Ducati was done at the Ducshop in Atlanta. Zytek is a renown European operation that has built many LeMans winning engines, and is the current supplier for the Formula Renault series (500+hp 3.5L V8's).
http://performanceracingoils.com/dynofriction-ezp-9.html
And for further info, including articles in engineering publications (Race Tech Magazine, Racecar Engineering, etc.), please go here:
http://performanceracingoils.com/tech-articles-ezp-3.html
It has been the recipient of multiple awards for the results:
http://performanceracingoils.com/newsawards-ezp-7.html
If you'd like for me to address anything specifically that you find outrageous, I'd be happy to. There are some outliers, results-wise. The SAE article quotes what is published as "normalized" power. They run up the dyno, cut fuel, and measure the losses as the dyno winds down. The results of the two tests showed different losses on the wind down. I do not agree with this method, and those two numbers should have been the same. Still, the measured wheel horsepower was about 2.5%, which is perfectly in line with a great many other oils we've seen.
The Fast Ford article that showed a huge jump in mid range torque is also an outlier, and yep, hard to believe. But then look at the top end, it actually falls (unlike the Vauxhall in the sister publication). Aftermarket turbo - what I personally believe happened is that the Ford uses a journal beaing turbo, and the NT enabled it to spool faster, which would certainly give you the results you see. Towards the top end, I believe the intercooler became heat soaked, and as a result, timing was pulled, which caused the slight drop off in the top end. Just speculation, but it seems to make sense.
I'll be happy to address any other questions. I have a background in engine development with an OEM, so I should be able to answer any questions somewhat intelligently (just don't ask my wife!).
BTW.....12's in a 4300# grocery getter is awesome! What is it?
As a reader of both of the Brit rags; Racecar Engineering, and Race Tech, I for one, most definitely know about (and trust) Zytek!
I am hoping to get some of the same 'magic' for my noisy, gear oil quick-shearing, 10 bolt, that those BTCC, and World Rally peeps got in their primo, exorbitantly priced, Quaife/X-Trac/FFD/etc. gearboxes when I switch to the millers NT 75W-140.
BTW; is there ANY chance that Millers will ever market their NT add pack as a separate additive for oil???
I'd love to try the 0w-30 or 5w-40 in my cars, but at 4 times the cost of my usual synthetic oil deals plus shipping is a hard pill to swallow.
HI, just to add to the discussion, I have been a long time consumer of Millers products and can assure any doubters that they are a very reputable company whose reputation has been gained by solving customers oil related problems in a short time frame.
They have solved for instance a gear dog ring problem in the early f2 rally Ford escorts
In endurance racing they were one of the first lubricant suppliers to come up with a solution to fuel dilution causing failures.
In truck racing they came up with a fuel additive which dramatically reduced smoke and provided fuel system lubrication.
There products are not the cheapest but quality is second to none and they are well respected in both the motor sport and also road haulage communities.
Just to state I have no connection to Millers apart from being a satisfied customer for many years, best wishes gus.
Originally Posted By: 67King
Originally Posted By: gogozy
i know this is lubricant related forum, but i have serious concern about impact of nano technology to environment, and health. I think they shall be tested like drugs, and disclose all the detail/result first, before being available for use by anyone - even in military uses.
I understand and appreciate the concerns, but I'm not sure I agree that an additive to an oil for use in internal combustion engine should undergo FDA approval.
Every product should be checked for safety, but engine oil and additives seem to be an exception in some countries. You can still use Lead additives if you don't like the neighbours kids!
Originally Posted By: MolaKule
From the SAE link:
Quote:
Engine friction arises from two primary sources: viscous losses and boundary friction.
I would have stated it this way:
Engine energy losses arises from two primary sources: viscous losses and boundary friction.
Quote:
“The power gained by cutting frictional losses was independently demonstrated in rolling road tests on a Porsche 911 RSR,” he explained. “With a conventional 10w60 grade race lubricant, the car produced 200 kW, measured to DIN70020. On replacing the engine oil with Millers CFS 10w60NT Nanodrive, the result was 211 kW, an increase of 5.6%.”
That's a gain, after rounding up, of 15 Hp. The decision for each person would be,
Quote:
Does the 33% increase in price yield enough of a horsepower gain to make it cost effecteive?
Long term engine friction is also effected by corrosion factors, so a long term study is needed to see how a new oil additive works. Increasing the Moly content in a race oil can improve power or mpg figures slightly, but it does have side effects. The big question is about the longer term pro's and con's.
I see the 4 point ball test got used again, which is a very popular snake oil test, even though it was designed for gearbox oil comparison.
Long term life of most Porsche blocks is heavily influenced by detergent content and high temp shearing and I would be surprised if a new oil could beat products from the big players in longer term test. I think neat bleach can provide better one off results in the 4 balls machine.
Well, we understand that any new technology will have skeptics. The oil is clearly not for everyone, any more than smart phones were not for everyone a couple of years ago. Our focus is on early adopters who are interested in newer technology and a better product. If you have an aversion to new technology, this product is not for you.
That said, I will be more than happy to address as many questions as are brought up. For questions about the oil becoming corrosive, please see this link, for a long term test on a Porsche. Yes it is a race car, and yes it is 1700 miles - but that is 1700 race miles, which is a good 3-fold increase over a more typical drain interval: http://performanceracingoils.com/PDF/longevity_case_study.pdf Note robust TBN. Nanotechnology is not like MoS2, it does not shear and contribute to a building up of acid. FWIW, my business partner and I own a total of 6 Porsches, so we are pretty familiar with them (air and water cooled, flat 6’s and I4’s).
Additionally, the gear oils, which have been out for a few years, are being specified by an increasing number of gearbox manufacturers, due in large part to observed increases in lifespan of the gearboxes. Both Samsonas and KAPS now specify Millers in their gearboxes. You can read some comments attesting to the drastic durability improvement here: http://performanceracingoils.com/PDF/BTCC_comments.pdf The gear oil has been under evaluation by a VERY successful F1 team over the past couple of years. It was slated to go in this year, but due to the tight constructor's championship race, it was not. Will be in next year. The testing to date has given a couple of valuable pieces of information. First – as mentioned previously – the NT does not shear down like your more common EP additives, meaning less heat is put into the oil. The powertrain dyno used by this F1 team has an external water bath to maintain gearbox oil temperature. On the dyno, the water is heated. There was an approximate 500 Watt difference in the power required to heat the current technology gear oil and the NT gear oil. 500 Watts less heat is being put into the oil, because it is MUCH more robust to breakdown than MoS2. Second, the gearboxes are required to last for 5 Grand Prix’s. As you can imagine, they are engineered to be as light as possible, meaning after 5 Grand Prix’s, they are worn out. When the NT oil was used, wear was greatly reduced. As a result, this team decided to keep running the gearbox to determine the lifespan of it with the NT oil. After 7 (again, dyno simulated), there was a non oil related failure (input shaft bearing), which caused an end to the test. The gears still showed very little wear.
Bryan Herta Autosports, which fielded the 2011 Indy 500 winning car, has a 3 year exclusive deal with Millers on the gear oil, it will be in IndyCar this year. The engine oil may be in some cars, as well, that is to be determined. Again, early adopters looking for the latest and greatest, or anything to give them an edge.
I believe you may be confusing the ASTM D4172 4 ball wear test, which is an industry standard test with the, um “cross-axis friction test” that is used by purveyors of chlorinated paraffin or similar products that lack the engineering pedigree of a 130 year old company like Millers. My personal experience with both one of the largest companies in the world, and a few high tech startups is that the level of innovation found in smaller companies is much, much more common than gigantic companies with bureaucratic processes that rival the old Soviet Union government. Besides, at this point in time, Millers is too small to even produce enough oil to threaten the large companies – why would they invest millions upon millions of dollars to improve their product?
Sorry for being long winded. Trying to avoid any ambiguity while addressing any legitimate concerns that may be brought up.
sorry not mean to side track this, but I am concern about this because lubricant are being handle and use by many people, and there is no way to contain them even in the engine, oil leaks, blow by, egr spill them out. I don't think there have done much of the "damage" study on nano technology in the past. we often develop something and discover it's harm to ourself or environment much later. I am not saying FDA need to get involve, but general public shall be aware, that due to size of the particle, and none-existence of such structure in natural environment, we do not know how our body, or environment will interact to it, and the developer shall bear the cost to show the test result to the public. I bet these nano oil will be much difficult to cleanup in a spill, the oil stains are probably impossible to remove from anywhere, does that mean micro-organize can not break it down and so it stay in such form for 1 millions of years? does the oil particles from til pipe are so small and resistant to breakdown, that it bypass most of the traps in nose and throat, and what happen to lung bubble when it cling to it? I don't know, but I like to know, because there is no structures like during evolution of all kinds, our body like don't know how to reject it, and what happen when my body accumulated enough of it? does my skin become silky? do I skate without skate on the ice, or even concrete surface, will I become one that never need personal lubricant? I don't know, but i want to know and WE need to know. I probably just went to far in the oil forum; as much as i welcome this new chapter, i also want it to be safe. thanks.
I am uncertain if there was a question directed to me or not in there, or if it was just a general gripe about established protocols. Virtually every chemical compound or blend of stuff has an MSDS associated with it. They are incredibly easy to find for anyone who has serious concerns. Here is the MSDS on one of the products listed: http://www.millersoils.co.uk/pdf/safety/7707.pdf
It is not a hazardous material by any testing method in use today, and if it ships, it has to have undergone whatever testing is internationally recognized I have to deal with forms every time I bring in some of the fuel additives, but not the oils. http://www.phmsa.dot.gov/international for more info. If you have an issue with the type and level of testing done on any products, I would suggest you contact your elected official. But be careful what you ask for - airbags were mandated and they killed a lot of people. MTBE was mandated and now it is a groundwater pollutant.
I could comment further, but this is already getting way off into the political area. I am more than happy to answer any legitimate questions people have, but regulatory questions are not something I am qualified to answer. Again, please contact your elected officials for those quesitons.
I always look at new oil products, but all I see is results, no independent lab tests or comparisons with other oils. Big oil companies move very fast with new additives, it is only the manufacturers approvals that slow them down in paperwork terms. Testing is expensive but I would have thought sponsoring a well know lab like Blackstones to run a few sports cars around with different oils and then publishing the data would be far more effective than bouncing around 4 balls results. The best proof of the pudding is in real world results in a full blind trial against an existing major brand race oil.
Originally Posted By: CATERHAM
Interesting but I'll wait for the independant test results.
Nano-particles from the sound of things are not exclusive to Miller's Oils and as mentioned G-Oil makes similar claim in their race oil.
If their is something to it the majors will incorporate it soon enough or perhaps already are without the hullabaloo.
Some of us are also waiting for the majors to incorporate high VII oils to see if there is something to them.
This is the third time I will have posted links to independent tests.
Zytek - http://www.performanceracingoils.com/images/FRenault.jpg
Rogue Motorsports, example 1 - http://www.millersoils.co.uk/news/2012/281112-Toyota-GT86-Power-Test.asp (http://performanceracingoils.com/PDF/BRZ_FRS_factory_fill.jpg for just the curve)
Rogue Motorsports, example 2 – http://performanceracingoils.com/PDF/Toyota_MR2.pdf (http://www.performanceracingoils.com/PDF/Toyota_MR2_dyno.jpg for just the curve)
JB Racing, example 1 – Fast Ford publication: http://performanceracingoils.com/PDF/2012_August_Fast_Ford.pdf (http://performanceracingoils.com/PDF/Ford_Focus_ST.jpg for just the curve)
JB Racing, example 2 - http://www.performanceracingoils.com/PDF/Vauxhall_Astra_VXR.jpg is just the curve, there was an article in Total Vauxhall in I believe August, but we do not have that article.
Ducshop, run #1 - http://performanceracingoils.com/PDF/Ducati_test_1.jpg
Ducshop, run #2 - http://performanceracingoils.com/PDF/Ducati_test_2.jpg
Ducshop, run #3 - http://performanceracingoils.com/PDF/Ducati_test_3.jpg
EB Motorsports, the data may look familiar, as it is the subject of the SAE article - http://performanceracingoils.com/PDF/74_911_RSR_Dyno_Results.pdf (before and after, curves only http://www.performanceracingoils.com/PDF/Porsche_RSR_before_Nanodrive.jpg and http://www.performanceracingoils.com/PDF/Porsche_RSR_with_Nanodrive.jpg)
Brno University of Technology - http://performanceracingoils.com/PDF/Skoda_dyno_results.pdf (sorry, don’t have curves for this one)
I will not mention the competitor's oils by name, but you can find out what they are. IN some cses, it is Millers non-NT version. The Zytek was on a spec Formula Renault in 2011. The oil was a spec oil, too.
Independent recognition and awards:
Race Tech Magazine’s Most Innovative New Product in Motorsports, 2009 Winner - http://performanceracingoils.com/PDF/Innovative_Motorsport_Award.pdf Note here it beat out a data acquisition system from McLaren and the KERS system from Williams. A mention still up on their website: http://www.world-motorsport-symposium.com/info2.cfm?info_id=105873
Race Tech Magazine’s Most Innovative New Product in Motorsports, 2012 Finalist - http://www.performanceracingoils.com/PDF/2012_WMSMINP_nominees.pdf
Motorsport Industry Association’s Business Excellence Award for Technology and Innovation, 2013 - http://www.performanceracingoils.com/PDF/2012_WMSMINP_nominees.pdf
And finally, here are several publications about Millers, mostly engineering publications, along with a few others:
Race Tech Magazine, example 1 – Finalists for Most Innovative New Product in Motorsports, December 2012 - http://performanceracingoils.com/PDF/2012_WMSMINP_nominees.pdf
Race Tech Magazine, example 2 – Masters of Low Friction, May 2012 http://performanceracingoils.com/PDF/Racetech_Mag_May_2012_-_Masters_of_Low_Friction.pdf
Race Tech Magazine, example 3 – Tiny Technology, Big Breakthrough, July 2009 http://performanceracingoils.com/PDF/Racetech_mag_article_Tiny_Tech_Big_Breakthrough.pdf
SAE International – if you don’t want to go back to page 1: http://www.sae.org/mags/aei/11201
Racecar Engineering – Grinding Back the Gears, June 2010: http://performanceracingoils.com/PDF/Eng_Solutions_mag_article_Grinding_Back_the_Gears.pdf
Race Engine Technology – Reassuringly Expensive, 2006 - http://performanceracingoils.com/PDF/Racetech_mag_article_2_Reassuringly_Expensive.pdf
And here’s the article to Fast Ford that I mentioned, August 2012 - http://performanceracingoils.com/PDF/2012_August_Fast_Ford.pdf
Can you show me where snake oil guys use the ASTM test? I haven't seen it, I do wonder if you are confusing it with the "cross action friction test" that guys selling chlorinated parrafin do.
I could show you HFRR tests, too, but that is an internal metric used by Millers, and it is used specifically to test boundary conditions, so while it is an ASTM test, it is not used in the manner the ASTM calls for, so it wouldn't qualify as "independent."
And finally, the oil manufacturers REACT to the OEM's requirements. I'm not sure how you got that impression, it isn't from trying to sell a product to them or having done engine development (I've done both, FWIW).
Next?
Thanks for joining the discussion 67King. It is refreshing to see someone from the industry address pro's and con's of their products to the end users/operators.
I am a Indycar fan and will follow how well the Herta team does this year. If Millers can help the Lotus engine, I'll really be impressed! I don't know what engine Herta will use, but the gearbox will be scrutinized. I wish Millers and Herta all the best.
I'm also a big fan of the little guy. I've been particularly impressed with how well Lubrication Engineers, Inc. lubricants perform with their proprietary additives. I've often wondered if Monolec and Duolec are nano-technolgy additives. They certainly do reduce wear.
As you've already mentioned, Millers lubricants might not be for everyone. But I might try a 30wt in my 2004 S2000 engine someday. It's NA still, but I really enjoy driving it and consider it a keeper.
BTW, seeing a 67 GTO in your signature put a smile on my face. I cut my teeth learning to drive a stick shift in my dad's during the late 60's on W. PA. country roads...a fondest memory!
Next?
That part above makes me laugh because nearly every new oil or additive companys says that. There is no legal reason for not publishing another oil companies name in such research.
For some odd reason you make comparisons with your own basic oil, I don't see what that proves because if you produce a cheap oil and a new expensive one folks kind of expect to to better.
All the press folks need to talk about new products and they always talk about new additives, but it does not mean much until they can publish true independent tests against other major brands like the ADAC does with tyres. Also if you advertise with a magazine they will publish any well written article, it does not mean the product is going to make engine oil history.
ALL YOU THIN OIL LOVERS WILL FIND THIS PART OF ONE ARTICLE ABOVE FUN READING:
There is a downside, however; reducing viscous losses by using thinner oils risks increasing boundary friction and reducing engine life through increased wear. Boundary friction occurs where the oil films are so thin that opposing metal surfaces begin to interact with each other.
Mann adds that these conditions exist between piston rings and cylinder bores as well as in the crankshaft bearings as they begin to rotate during engine start-up.
As more vehicle manufacturers introduce stop-start technology, start-up conditions will occur much more frequently—from an average of around 40,000 times in a lifetime to a likely 1 million.
My company believes in a very, very common and unspoken ethical line in marketing. You just don't call out your competition. You let the product sell on its own merit. I'm not going to change that for you, sorry.
Perhaps you are not familiar with SAE. It is a professional organization that is funded through member fees, not advertising. So quoting them directly contradicts the assertion that they are publishing articles due to advertising. As for the others, a very smiple search of the author's history would show that they are either employed by said magazine, or are feelance writers, with backgrounds extending well beyond just one particular company.
Race Car Engineering, Race Tech Magazine, SAE International, and Race Engine Technology are not "most magazines." They are very well respected engineering publications. They are the magazines that race engineers read. Their awards are real, not tainted by any kind of marketing hype. And as I explained to you in THIS thread (a very good thread for anyone else still reading), Millers is not a marketing company. The article, and much of what Millers is promoting, is about the technology. And internal benchmarks are the first and easiest ones to do.
The MIA, Motorsport International Association, is trade organization, not a media vehicle. It is funded through membership fees. Its awards can't possibly be tainted by advertising.
As for the specific point about start-stop, it is of critical importance. When I was at Ford, I saw fuel economy turn cycle plans upside down. I saw Ford willingly spend 30% mroe on an engine to get 3% better fuel economy. Reducing viscous losses is one of the many ways fuel economy can be improved. As with everythign, there is a downside. That is what Martyn is addressing - the increase in boundary conditions beyond just the typical ring/bore interface near TDS and BDC.
Now, I'd prefer we get back to the subject of this thread - the technology at hand. This is a good way to pull it back into the fold. Why nanotechnology? As Martyn mentioned, more frequent stars will become a bigger factor as hybrids expand their market share, and as ISG's make their way into pure gasoline/diesel applications. Here is a pictoral graph representing what the technology does. It is against another Millers product without NT. Again, this is about the technology, not about Millers. The NT's property is sticking to the metal surfaces and thereby drastically reducing CF in boundary conditions. Here's how that impacts things at start-up:
Again, I will refernce the prior thread, and point out that in 6 pages, the majority of the contribution was from other people, including the thread starter, and that the majority of the discussion was about the technology, I applaud them for their efforts to educate themselves on technology and how it may affect lubricants. I enjoy that kind of dialogue. I apologize that I have let myself become argumentative while attempting to educate the readers here against wild speculation and misinformed allegations. Anyway, I'm going to give you the last word. I am more concerned about educating the public than I am about winning an argument. I am, however, more than happy to answer any legitimate questions anyone may have, so long as it does not get into confidential territory.
I think the readers here would be best served, also, if the unfounded accusations would stop. I would recommend you re-read the threads for the input of others for the reputation of Millers if you are not familiar with them.
Herta has a very close association with Honda, but any deviation from the baseline oil has to be approved by Honda, first (and the deal was just finalized in late November). I'd love to elaborate beyond that, but anything else is confidential. I really hope that will change and I'll be able to share more moving forward.
Our very first customer was a big autocrosser who had issues with the rear end of his S2000. Very cool cars, I got to drive one on the test track in Dearborn when I was still at Ford.
I bought the GTO in 1989 as a project when I was 15. Drained my savings, but really enjoyed it. It is now back down in epoxy primer, but a bit on the back burner relative to other things I have going on. Was hoping to have it back together by the time I turn 40, but that's a long shot, at best. Still a fun car, though no longer what I'd consider fast - technology has done amazing things for today's cars, evidenced by 4 bangers with 1/3rd the displacement being able to blow the doors off of the GTO.
The technology is interesting but without a majot brand comparison all the press are saying is that it increases power slightly or increases fuel economy and in wear terms is better than your last oil. You can say that about any good new oil, but once you can show it beats the market leaders the investors will get interested. Where can you buy this new oil at present??
Originally Posted By: pbm
I just saw an ad (in October 12' Motor Trend) for a 'ceramic nanotechnology' additive made by Xado Co.
It seems to make the same 'engine coating' type claims as a host of previous additives.
I assume the only real difference it will makes is in one's wallet...
Liqui Moly Ceretec also plays the Ceramic game as do others and most confuse the results by including Moly in the same bottle. I use Castrol Edge as a baseline comparison and not one additive or different normal oil can seem to beat it.
You currently get 3.94 million results in Google search if you type in "nano particle engine oil"!! The snake oil companies have hit the first 10 pages real hard.
This article is the top ranked in Google about nano particle tests (SAE approved):
Nano Nano trucking.
The street oils, at present, are only available through us (www.performanceracingoils.com). You can also try Performance Oil Store, as we have a close relationship with Barry and he is carrying some of our non-NT street oils. For the race oils, you can again buy through us directly, or from Paragon Products, Apex Performance, LN Engineering, Essex Parts, Gabriel Maintenance Ltd (in Canada).
Outside of North America, you can look up on the Global Network, near the top on the right, there's a pull down tab: www.millersoils.co.uk.
Also, the dyno curves include a mix of several different brands. The RSR, Skoda, and MR2 were Millers non-NT and Millers NT. All the others were competitors and excpet for the Ducati, I've given enough info in the thread where you can find out.
