Actually it happened a few weeks ago, but my '96 Saturn SL2 made it to 150,000 miles!
The Saturn has been in the family since new, and in that time, it has only stranded us twice. Once for a failed alternator at 63k, the other time for a broken serpentine belt tensioner at about 89k.
Over the course of 150k, it has required the following repairs and replacement of these normal wear items:
1) 2 Sets of Front Brake Pads (89k, 147k)
2) Front Brake Rotors (147k)
3) Front Calipers (147k)
4) 2 Sets of Rear Brake Pads (89k, 115k)
5) Alternator (63k)
6) 2 Serpentine Belt Tensioners and Serpentine Belts(89k and 148k)
7) A/C Recharge (Summer 2009)
8) PCV Breather Hose (60k)
9) Starter (102k)
10) Oxygen Sensor, upstream (114k)
11) Transmission Valve Body Cover gasket (50k, but fixed at 98k)
12) Valve Cover and Spark Plug Tube Seals (98k, but was leaking for a while)
13) 3 Motor Mounts
14) 3 Batteries
15) Radiator (129k)
16) Heater Core (~140k)
17) Thermostat, radiator hoses and cap (121k)
18) Water Pump (~147k)
19) F/R Struts and Front Strut Mounts (129k)
20) Rear Sway Bar End Links (Not sure, but definitely before 100k)
21) Engine Coolant Temperature Sensor (never broke, but replaced it before it would cause the infamous driveability problems)
22) Trunk Wiring Harness (wires snapped, friend respliced the wires)
Those are the items that I have fixed. These are the items that are still unresolved:
1) Cruise Control (works intermittently)
2) Intermittent Harsh Reverse Engagement (Valve body issue, but not bad enough to fix)
3) Leaking Power Steering Pump (only slight leak)
4) Headgasket (this one just developed this month, it's an external leak that has been mostly stopped thanks to Bar's Leak's Liquid Aluminum Solution)
5) A/C Compressor Clutch (slight wobble)
And it burns 1 qt of oil every 1200-2000 miles depending on the driving conditions.
So there you have it. That's the Saturn ownership experience so far after 150k. I am actually quite surprised by the amount of repairs and normal wear items it needed to get to 150k, especially since a good portion of these repairs were needed before 100k. We'll see how the Altima fares at 150k, hopefully it will be better.
5) Alternator (63k)
9) Starter (102k)
13) 3 Motor Mounts
14) 3 Batteries
15) Radiator (129k)
