He won't approve the AC, coolant temp sensor, etc unless it completely failed. Oh well. At least he approved the most important items.
Here's my quick little proposal to him, please give me feedback:
quote:Thanks.
Items needing service/replacement: 1) Valve Cover Gasket and Spark Plug Tube Seals Reason: Oil leakage due to failed spark plug tube seal on cylinder #1. Valve cover gasket kit includes spark plug tube seals, and the entire valve cover must be removed to replace the spark plug tube seals. Parts Required: Genuine Saturn Valve Cover Gasket kit from SaturnParts.com, for 96+ Saturn 1.9L DOHC with Composite Cover Cost: $18.24 2) Spark Plugs Reason: Part of 90k service, also because spark plugs must be removed prior to removing the valve cover. Parts Required: (4) OE NGK #5643 Copper Spark Plugs, Standard Plug #BKR5ESA11 Cost: $1.70/each, $6.80 total 3) Spark Plug Wires Reason: Deterioration of "boot" for cylinder #1 due to oil contamination, also because wires should be replaced around 100k miles due to wear. Parts Required: ACDelco Spark Plug Wire Set for Saturn 1.9L DOHC, Part #744Q Cost: $23.79 4) PCV Valve Reason: PCV Valve must be removed prior to removing the valve cover. Blow-by buildup causes valve to be sticky. Cost is minimal to replace. Parts Required: Genuine Saturn PCV Valve from SaturnParts.com for 96+ Saturn 1.9L DOHC, Dorman #42341 PCV Valve Groomet from RockAuto.com Cost: $2.25 for PCV Valve, $1.99 for PCV Valve Groomet 5) Torque Axis Mount, a.k.a. "Upper Motor Mount" Reason: Constant vibration at idle signals a failed Torque Axis Mount, an extremely common problem with all Saturn S-Series. Consequences of failing to replace the mount include damaging the other three mounts, and excessive vibration may loosen some parts. Parts Required: Genuine Saturn "Torque Axis Mount" from SaturnParts.com Cost: $49.50 6) Clean EGR valve and throttle body Reason: Overtime, carbon buildup in the EGR valve will affect performance and emissions. Throttle Body Cleaning will improve driveability. Parts Required: Carb Cleaner from Walmart, Fel-Pro Throttle Body Gasket #61177 from RockAuto.com, Fel-Pro EGR Valve Gasket #70789 from RockAuto.com Cost: $1.21 for EGR Valve Gasket, $3 for Carb Cleaner, $1.61 Throttle Body Gasket 7) Flush and bleed Brake Fluid Reason: Brake fluid is hydroscopic. Moisture will negatively affect expensive brake components, deteriorate pedal "feel," and lower the boiling point of the fluid, thus increasing one's danger of fluid boiling after repeated, high load stops. Parts Required: 1 quart of Prestone DOT3 Brake Fluid from Walmart Cost: $4.00 8) Replace Power Steering Fluid Reason: Power Steering fluid needs to be replaced periodically due to depleted anti-squeal additives and friction modifiers. Replacing most of the power steering fluid will allow for "smoother steering." Extracting the contents of the reservoir with a turkey baster on a bi-weekly basis until several quarts of fluid is used is an extremely simple and cost-effective method of replacing most of the power steering fluid. Parts Required: Turkey Baster, three quarts of SuperTech Power Steering Fluid Cost: $5 for Turkey Baster, $2/quart ($6 total) for Power Steering Fluid 9) Replace Automatic Transmission Fluid and "Spin-On" external Filter Reason: Required as part of 90k service. Parts Required: Dexron-III(H) Automatic Transmission Fluid (already at home); FRAM P6646 Automatic Transmission Filter from RockAuto. Cost: $5.85, though purchasing two may be a good idea due to exceptionally low price. 10) Replace Engine Air Filter Reason: Required as part of 90k service. Parts Required: Pro-TEC #331 Air Filter from RockAuto.com Cost: $7.00 11) Replace In-Line Fuel Filter Reason: Required as part of 90k service. Parts Required: Wix 33575 In-Line Fuel Filter from RockAuto.com Cost: $19.27 12) Replace Engine Oil And Filter Reason: Oil already has > 3500 miles, plus the oil may be contaminated by any dust when the valve cover is removed. (Parts are in-stock at home) 13) Inspect Brakes Reason: Part of 90k service, wheels must be removed to bleed brake system already, plus there appears to be a rubbing noise while driving. RockAuto: Subtotal: $73.37 Less 5% Discount Code (483468362798)= $3.67 Shipping: $23.20 Total: $92.90 SaturnParts.com Subtotal: $69.99 Estimated Shipping: $15.00 Estimated Total: $84.99 Estimated Final Cost of proposed repairs: $177.89
