Originally Posted By: DoubleWasp
From what i know of the the VG30DETT and DOHC V-engines in general, you almost certainly lost out due to oil starvation.
Coming to what someone was saying about the GT-R; it does not have cross tubes exactly. It actually has two small electric pumps to forcibly pull oil out of the valvetrain area.
When Steve Millen was racing his 300's, he actually had to relocate the PCV system from the cam cover to the valley in order to stop the oil from flooding up into the PCV system and being consumed by the engine. This mod is also now a factory arrangement on the current GT-R.
DOHC V-engines of all types, including our DOHC Ford V8s are notorious for filling the valvetrain area with oil during high rpms, taking it away from the sump. A proper dry sump system for these types of engines usually has 2 full stages or 2 mini stages dedicated to the cylinder heads to extract the oil from them. In between this condition, normal sump demand by the rest of the engine lubrication, low sump capacity, and the G-Forces, I'll say you never had a chance.
You might only be on street tires, but even street tires can tolerate momentary G-Forces well above 1G, in which the oil is more likely to climb up the cylinders than stay on the bottom of the sump.
If it were me, I would get an Accusump or other brand of accumulator, oil temp guage, and either one or two large oil cooler(s). People don't like to think of the oil system as a cooling system, but it is. The engine oil gets a whole lot closer to the hot engine parts than engine coolant ever does. Have you ever seen an FC Mazda RX-7 or Porsche oil cooler? Massive. Their OEM coolers are preferred over any aftermarket designs.
Look at any factory racer, or racing package, and you are guaranteed to find one serious oil cooling system. Gotta upgrade.
Just ask yourself; do you really feel comfortable letting this weak [censored] manage your engine oil cooling duties?
http://z32.wikispaces.com/file/view/Used..._Oil_Cooler.jpg
I think the power steering cooler on my van is larger than that.
Great information
and dear Jesus that's a small cooler!
