i bought a brand new lowrider sport in 1990
I HATED IT, thought it'd be the modern equivelent of a commando or bonnie-WRONG
then i tested a fatboy, LOVED IT so i bought 1 brand new in 1992 (january 8), turquoise and ivory
they let me open up the cardboard "crate" myself, so no ace apprentices took it around the carpark. had it for 9 years in nz and 9 in oz
ran it in easily, 300km ride with my (then) wife on board
below are the bits and pieces and probs that i've had in the 18 years of ownership
1 starter relay
1 stator
1 primary gasket
1 voltage regulator
1 starter clutch sprag
1 pull throttle cable
1 set screamin eagle "off road" mufflers
1 headlight bulb
3 tail light bulbs
1 speedo bulb
1 front rotor, buggered by some aftermarket pads
2 sets front brake pads
1 rear rotor, buggered by riding off with a padlock attached
1 set rear pads
1 aftermarket foam aircleaner element
1 topend gasket set, the rear cylinder base gasket leaked from early on
1 gearshift return spring
1 EV3 cam
1 set adjustable pushrods
1 inner cam bearing, it was a torrington, not the infamous ina, changed it anyway
1 set cam followers-1 roller had broken its needles- only found out coz i wanted to see the inside of the filter- can you say lucky ?
4 wheel bearing seals, greased the bearings once
1 "X" ring chain and sprocket set, replaced the belt when it broke dragging a car load of teens
about 7 batteries, oddysey in there for about the last 5 years, never go back to lead acid
tyres? i get about 10,000 km from a rear marathon and about 15,000 from a front
1 left hand mirror, head just fell off the stem
oil? change every 2-3,000 kms, tried all sorts inc boutique syns, the last 3 years on 20w60 diesel lube
filter? every 2nd oil change, car equivelent
primary? every 5,000 kms, currently using plain dex 111, tried allsorts (chain about 1/3 adjustment used)
gearbox? every year, currently using mobil heavy duty 80w90, tried allsorts inc boutique syns
forks? every year, tried allsorts, currently running belray heavy
chain? anything EXCEPT WD 40, currently using putolene syn spray. chain has only had initial adjustment at about 500 kms. racked up 44,000 kms so far on the conversion
been trailered home only once, the belt incident-haha, that'll teach me
all work bar the cam bearing, gear spring, starter clutch, stator and regulator was done by me. i wasn't confident inside the gearbox and the shop wouldn't warrant the elec parts unless they fitted them
so, 18 years on, 113,000 kms, 50 mpg (65 before the cam change), nil oil consumption, this has prolly been the "best" bike i've owned
sure, it vibrates, is slow, drags on corners and leaks a little oil and gas
BUT IT'S ALL I EVER WANTED IN A MOTORCYCLE !!!
( P.S. the '69-70 bonnie was the most fun ;-) )
1 starter relay
1 stator
1 primary gasket
1 voltage regulator
1 headlight bulb
3 tail light bulbs
1 speedo bulb
1 set rear pads
1 EV3 cam
