There is an internet (one that will deliver to you) offer of a 2013 TL with fewer miles for $12,000. 7 years newer and fewer miles for the price of what you have put in the 2006.
I still have 2 Vibe GTs, both with 6sp manual. Super fun to drive. The 2ZZ-GE engines probably won't make it to 280K but both are still going strong at ~125K miles. Recently replaced clutch and timing cover gasket on both. Orange car needed a new intake camshaft, silver car needed 3rd gear synchro. All work done in my garage.I miss my 280k mile Pontiac Vibe... Aka Toyota Matrix, or Corolla Hatchback.
I almost bought one years ago. Haggled with seller, ended up walking away. Kicking myself to this day.An '08 Type S with the basket wheels + the 6 speed LSD is worth a fewnow
Sadly, most of the good ones are gone. There's a few still out there, but they hit the price point where kids could get them and modify them...and then wreck them. That and there seems to be a greater concentration in the NY/NJ area, so lots of salt cars on top of that. I see a couple in the TL FB groups every week that get plowed into something and destroyed.I almost bought one years ago. Haggled with seller, ended up walking away. Kicking myself to this day.
I don't think he invested in financial gains down the road. This looks more like an investment into personal joy, fun, and happiness factor. And that type of investment I support 100%.Only way I would have replaced all that stuff is if I did it myself. To pay a shop to do it is not worth it and I would have not bought and invested that much in repairs for a 17 year old, poorly maintained vehicle. I highly doubt you would ever fetch would you have totally invested into it.
Thank you, Dr. Phil.I don't think he invested in financial gains down the road. This looks more like an investment into personal joy, fun, and happiness factor. And that type of investment I support 100%.
You should try making time to do something that makes you happy. Numbers don't always tell the full story.
Honda/Acuras are nimble handling, fun to drive, have exciting dashboard/speedometers to look at, and when you're sitting in one, it just feels right.I had the last oil leak fixed yesterday, the rear main seal was replaced. I bought this car in September 2021 from a friend for $4K. I spent over double that in fixing the oil leaks and replacing worn out parts. The more I drive it, the more I love it. The J32 V6 is so smooth and this is the pinnacle of Acura cars for being driver centric and fun to drive. I bought the car with 159,000 miles and it has 166,000 now. I ride my motorcycle most days and the TL is my back up car. This is what I replaced on it. I had two different shops perform this work and both said the J32 will easily last 300K.
tires
wheels
front rotors and pads
rear pads
4 struts
upper and lower front control arms
front ball joints
front end links
front sway bar bushings
front outer tie rods
3 transmission mounts
2 engine mounts
valve cover gaskets
valve adjustment
spark plugs
oil pump reseal
spool valve seals
cam seals
front crank seal
rear crank seal
cam plate seals
vvt solenoid seal
water pump
timing belt
timing belt tensioner
windshield
They do?The J32 sounds like wet farts blown through a trumpet.Could've bought a very decent RSX Type S for $12,000.
