I now have an AC issue with my Explorer
Rochester, MI, US, World
In addition to a failing PTU, my 2016 Explorer has no AC. Went to test today, as it was quite warm outside… nothing. Compressor not turning. Checked fuses, all okay. Then I blipped the Schrader valve for the high and low side… completely flat. Thankfully, with the help of YouTube, I figured out where the leak was. Near the driver’s side muffler, there are two connections for the rear HVAC. They get corroded and leak. Sure enough, I see lots of corrosion and oil on the connections.
I’ve ordered new o-rings and gaskets for these, which were cheap. Assuming I can get them replaced, I know that I have to vacuum the system and then recharge. I’ll rent a vacuum pump and manifold gauges to do this. But, do I need to add more oil to the system? I’m not replacing any components, other than seals. I suppose it wouldn’t hurt to dribble a little into the line before I add refrigerant.
If you're opening the system to atmosphere (which you will be doing), replace the desiccant. Every time. Do the job correctly.
If you only have a bit of oil weepage (not leakage) at leaking joints, you needn't add oil. The systems are sensitive to over-oiling.
You need to fill by weight, not by pressure. Before that need to pull a vacuum and see it's held for 30 minutes.
I think others would suggest replacing the orifice and accumulator.
