My Car: 1996 Acura Integra SE, 1997 B18C JDM ITR motor (totally stock inside) with somewhere around 105,000 miles on the engine at the time of the change.
The Oil: Motul X-Lite 0w30 running through an Amsoil EaO oil filter. This oil was run for 9,756 miles and ~6.6 months, during which time 4.2 quarts of make-up oil was used.
Relevant mods: Amsoil EaA air filter on a no-name short ram intake, magnetic oil drain plug.
Other: The PCV inlet (for the line connecting the valve cover to the intake) on the intake arm is, like all aftermarket intakes for these cars, not slash cut...it just goes in at a right angle on the arm. After doing this oil change, I also modified that as such (where the bottom of the inlet is pointing towards the throttle body) in an effort to hopefully help crankcase pressures and reduce oil consumption. We'll see if it did anything at the next change.
On to the results! The column with a sample date of 8/25/08 is GC (Castrol Syntec 0w30) and 2/9/08 is Motul X-Cess 5w40, both on the same engine.
Previous UOAs:
GC
X-Cess
Amsoil TSO (this was on my old non-VTEC engine...original to the car)
Previous UOAs:
GC
X-Cess
