Motorcraft FL-400S or Fram TG / EG
Originally Posted By: InhalingBullets
Originally Posted By: DerbyDave
Originally Posted By: crazyoildude
Fram makes the ultra and that filter is pretty well constructed, Period!
The Ultra seems like overkill for a 5000 mile change interval
seems like running the Ultra for 2 oci's would be acceptable.
I'd do this
Originally Posted By: ZeeOSix
Originally Posted By: wsar10
Any links to support the pessimistic culture (for a lack of better definition)toward MC filters !!!
Some links here: LINK
WOW !!! Thank you for the info, I remember talk of a spreadsheet but did not ever see it until now..
Thanks again.
Originally Posted By: slacktide_bitog
Motorcraft is very similar to the P1, and some of them have torn. Regardless, the issue has been fixed. Filters made from 2015-on will not tear.
That said, the CQ Red is a very good filter for the price.
Wholly [censored] ! Every-time I stock up on filters I read [censored] about them... except for NAPA GOLD.....
A few years back I bought 2 cases of P1 filters, I ended up using them at the shooting range !! Now I have stocked up on FL-820s and NAPA GOLDs... Currently my WJ has a MOPAR filter on it.
I did just run a FL-820s for a 9K mi OCI.... Awaiting UOA results and I will cut that filter open tonight (or this week at least).
I would not state the problem has been fixed for Motorcraft filters.
I tore this filter on an '04 Ranger 4.0L V6.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3996687/1
I cut a newer one to see if the problem was fixed. Changes were made but the pleat spacing is wide. This is the same area where tears occur.
http://www.bobistheoilguy.com/forums/ubb...Dat#Post3994586
So, I cut an unused Motorcraft. This one has wide pleat spacings as well as rust. There is a good possibility a tear will occur at the wide pleat spacings.
Unused Motorcraft FL820S cut & post
This CQ Red has very wide pleat spacing that might be an issue.
http://www.bobistheoilguy.com/forums/ubb...cut#Post4002381
This WIX wins the beauty contest.
http://www.bobistheoilguy.com/forums/ubb...ut_#Post4009590
Recent failures of Motorcraft filters do exist on this site.
Recent FL820S failure
Lots of filters in this one.
I am not sure that a reliable filter exists for less than $4 for the OCI / OFI all of you want to run.
Just sayin'
My 2 cents.
Originally Posted By: 901Memphis
Filters can vary based on the model number too. The Fram filters like the 3600,3387,3980 always have lots of media even in Orange can form.
901Memphis - This is true.
It should be pointed out that not all Motorcraft oil filter part numbers are bad and some deliver excellent results. The FL820S happens to be a problem. The same is likely true for Purolator and made by Purolator filters.
There have been posts of seriously abused Fram filters and they went the distance.
Just sayin'
My 2 cents.
This does not inspire confidence in Purolator or any of the filters they contract to make.
If this is the case a TG3600 would be more than sufficient for a 5K OCI. 99% efficiency in a filter rated for up to 10K OCI for just over $5
The confidence with Purolator produces has been going down hill since about 2 years ago when stuff like this kept popping up almost daily.
Yes the TG 3600 always looks good when cut open, it has lots of media and usually pretty straight too.
