OVERKILL
$100 Site Donor 2021
Originally Posted By: Ohle_Manezzini
Originally Posted By: CT8
High VI in a finished engine oil means higher viscosity improver amounts.
Do you really think so? Oils don't have natural Viscosity Index, some more other less?
If PAO6 has a VI of 135-140, and a finished oil is somewhere from 160-200+, then obviously:
* anything over 140 has VII
* the higher the VI, the more VII for any given basestock.
Not at all, Again. Mpao has a viscosity index of 200, without any VII.
Yeah, the one that is 156cSt.
Assuming we are talking about Mobil's mPAO, their thinnest SpectraSyn Elite mPAO is the 65, which is 65cSt @ 100C and has a VI of 179.
The other, thicker products, are the SpectraSyn Elite 150, which is 156cSt @ 100C and has a VI of 210 and the SpectraSyn Elite 300, which is 303cSt and has a VI of 241.
For any of those products to be useful they have to be significantly diluted with a lighter base that will have a much lower VI.
You could play around with the Widman Visc calc to get an idea as to what ratios we'd be looking at here. For example, if we wanted to blend an xW-20 with a 100C visc of 9cSt, making it a heavier 20 weight, we could start with some Mobil SpectraSyn 4, mixed with SpectraSyn Elite mPAO @ 72%, this gives us a 100C visc of 9.01cSt, perfect! That same ratio, using our 40C values gives us 50.13cSt. That results in a VI of 162.
Let's get even WILDER! We'll use the SpectraSyn Elite 300 with its even higher VI:, at 75% SpectraSyn 4 and 25% 300, we end up with 8.98cSt @100C, pretty good. We end up with 49.51@40C, which gives us a VI of 164.
Would be interesting to play around with the even lighter SpectraSyn 2 (1.7cSt) to see what that yields but generally oils with very high VI's are due to the presence of VII.
