Plawan Joined Apr 5, 2016 Messages 1,024 Location Texas Sep 8, 2022 #1 Which Motor-craft oil filter will fit my Ram 1500 classic 5.7? I’d like to use a base end bypass valve if possible. Thanks Shawn
ZeeOSix $100 site donor 2022 Joined Jul 22, 2010 Messages 50,192 Location PNW Sep 8, 2022 #2 Go to RockAuto, put in your vehicle and see what filters pop-up. Once we know some of the filters that engine takes, then someone will know which Motorcraft will fit, if there is one. https://www.rockauto.com/
OVERKILL $100 Site Donor 2021 Joined Apr 28, 2008 Messages 63,440 Location Ontario, Canada Sep 8, 2022 #3 Plawan said: Which Motor-craft oil filter will fit my Ram 1500 classic 5.7? I’d like to use a base end bypass valve if possible. Thanks Shawn Click to expand... FL-820S. It will be a bit snug, as it's the same as the larger 6.4L/6.2L filter (original RAM 5.7L filter before the downsize) but it usually fits.
Plawan Thread starter Joined Apr 5, 2016 Messages 1,024 Location Texas Sep 8, 2022 #4 OVERKILL said: FL-820S. It will be a bit snug, as it's the same as the larger 6.4L/6.2L filter (original RAM 5.7L filter before the downsize) but it usually fits. Click to expand... Great thank you
OVERKILL $100 Site Donor 2021 Joined Apr 28, 2008 Messages 63,440 Location Ontario, Canada Sep 8, 2022 #5 Plawan said: Great thank you Click to expand... You are quite welcome. I'm running the AMSOIL equivalent on the RAM in my signature, and the FRAM Ultra equivalent, the XG2, on my SRT.
ZeeOSix $100 site donor 2022 Joined Jul 22, 2010 Messages 50,192 Location PNW Sep 8, 2022 #6 Does the FL-820S (tearolator) still have a base end bypass? Not all Motorcraft filters have one.
OVERKILL $100 Site Donor 2021 Joined Apr 28, 2008 Messages 63,440 Location Ontario, Canada Sep 9, 2022 #7 ZeeOSix said: Does the FL-820S (tearolator) still have a base end bypass? Not all Motorcraft filters have one. Click to expand... Did the last time I checked. It was the original filter that was being pimped as having it, LOL, because it was the Modular filter.
4wd $50 site donor 2026 Joined Sep 21, 2010 Messages 35,601 Location Texas/Other via IAH Dec 18, 2022 #8 What about XG10575 ? I have a couple with the lower bypass and wonder if they are ok for a 5.7L
5 53' Stude Joined Mar 12, 2015 Messages 36,522 Location In the shop Dec 19, 2022 #9 4WD said: What about XG10575 ? I have a couple with the lower bypass and wonder if they are ok for a 5.7L Click to expand... According to parts catalog a PH 48 or PH 820 are the two correct filter options for a 5.7 HEMI
F flash7210 Joined Dec 18, 2022 Messages 138 Location Florida Dec 19, 2022 #10 Motorcraft FL-500S will fit. It's the same diameter as the PF48 / ph10060 but is taller. The XG10575 is the same size as the FL-500s
Deplorable Joined May 16, 2015 Messages 829 Location Louisiana Dec 21, 2022 #11 The Mopar MO-899 also has the base end bypass but has a nitrile ADBV. That’s if you can use the bigger filter.
D DibroTeam Joined May 14, 2013 Messages 64 Location Bulgaria Jun 9, 2024 #12 I have 5.7 hemi and use Motorcraft FL500s.
KCJeep Joined Jun 30, 2011 Messages 11,866 Location Mahzurrah! Jun 9, 2024 #13 If the 500 will fit it would be a better pick. The 820’s have largely been a poster child for “blech!” on here.
