- Joined
- Dec 16, 2022
- Messages
- 1,413
The 5.7 is all over the place when it comes to recommended "fit" oil filters.
Using both Fram Ultra and the Royal Purple web pages, the exact same 5.7 can have different oil filter numbers depending on year and model.
Ram 1500, Fram says "xg2" for years between 2009 to 2013. For years between 2013 to current, it says "xg10060" so 2013's can use either one.
Challenger, Fram says "xg2" between 2012 and 2019; but 2016+ it only says "xg2" for those models with the scat pack. Between 2016 and 2019, "xg10060".
Jeep GC the switchover date from XG2 to XG10060 is 2014 + 2015.
Ram 2500 it switches at 2013
Royal Purple has a similar thing going on, used to be the bigger 20-820 but switching over (same years as Fram) to the smaller 10-48.
So my questions: why would FCA change to the smaller filter specs, and secondly if I can physically fit a bigger filter that used to be OK back in 2010/2012, on my current 2022 5.7, is it safe to do so? The fram filters have smaller inlet holes on the XG2, any possible problems restricting oil flow with the bigger filters with smaller holes?
