Originally Posted By: ARCOgraphite
If MoS2 had real benefits in motor oil it would be used as an EP/AW in current approved oils.
Maybe, maybe not. There are a lot of reasons oil companies use an additive or not. Most are related to profit. Sorry if I seem cynical on this.
I say again, its not used in ANY ILSAC certified motor oil. PERIOD.
You are simply mistaken. Liqui-Moly makes a variety of oils, including Leichtlauf Special AA 5w30, which is GF-5 Certified. There are a whole list of their motor oils, most of which contain MoS2, listed on ILSAC's site. Many are not popular in the US, but that's hardly disqualifying. Regardless, you should not conflate oil company marketing and certification decisions with the utility of a product. There are simply too many other variables in the mix.
I ran it in the Honda (below) and I lost pressure and almost grenaded the engine.
I am sorry to hear that you lost oil pressure in your Honda, but why do you attribute this to the presence of MoS2? Exactly how did you lose oil pressure? What is the link to a particular additive?
Strangely enough, if you lost oil pressure because you lost your oil (leak, loose drain plug, stray bullet) MoS2 in your oil might have been your savior! That is a classic military use of this product.
We have used Liqui-moly in an RSX and the engine loved it - never ran better. Both Honda (including the Acura RSX) and Toyota use oil pressure to power their variable valve timing mechanism and MoS2 makes it work even better. About the only caveat on vehicles such as these is that using too heavy weight oil can mess up the mechanism. Too heavy oil does not actually result in a loss of oil pressure, but it will sure trip the oil idiot light. The mineral oil carrier in Liqui-moly additive is quite thin, so it should have no negative effect on this.
