$400 for an alternator??? That sounds crazy high to me.Very few that are less expensive. If the alternator wasn't over $600 I would put one on, I still may just to avoid all this messing around, if I can get it $400 its a done deal.
Decent parts are crazy high.$400 for an alternator??? That sounds crazy high to me.
Alternators are often easily repaired.Decent parts are crazy high.
I won't buy anything with a plastic pulley without first verifying that a metal one is not available. Also, if you still have the metal pulley, consider replacing the bearings on it and reusing the metal pulley part.Motorcraft belt tensioners that came on the vehicle with a metal pulley are now sold with plastic pulleys
I'm honestly not sure what the answer is beyond caveat emptor
Eric at SMA just posted a video about this problem. You indie mechs will probably have to start telling people you have to charge labor for a redo if they insist on aftermarket parts that fail. You can't do the job twice and get paid once too many times.
Sure if you can get parts (bearings are no problem) and the rotor or stator isn't open/shorted. The one I have had bad bearings so the rotor hit the stator, it is hosed. The used one I have is a real rat, lots of corrosion.Alternators are often easily repaired.
That's good to know. I've installed several aftermarket figuring -- like Eric said in the video -- how difficult can it be to build an acceptable blower motor? Apparently, fairly difficult.I called it in the comment section when the first video went up
I've never had an aftermarket blower motor last a week
You are spot on! For that reason unless you can diagnose a replacement part go with OE, chances are very good it will be a good one.I think the tough part is if you aren’t really up on some of these things like fuel trims or don’t really know anything about vehicles but maybe can change a part. How are they supposed to know the part they just installed is faulty. Now it gets brought to a shop and maybe the owner tells the shop such and such part is new or the minimum wage tech sees the new part and starts looking elsewhere for the problem assuming because the part is new it’s fine. Now this cheap part has cost the owner a lot of time and money and cost the shop time for diagnosis. This can make people shy away from the joy of car ownership and working on and modifying your own cars.
Find a starter shop even if it’s a journey. Call and tell them what you have and see what they can do for you . That’s nuts those prices. I have gotten all my starters and alternators rebuilt locally since the 80s by the same guy. I’ve never paid over $60 and unlike the big commercial plants if the bearings are even slightly iffy new ones go in. Chances are they will have a huge pile of cast off bins for salvage parts like castings ect…Sure if you can get parts (bearings are no problem) and the rotor or stator isn't open/shorted. The one I have had bad bearings so the rotor hit the stator, it is hosed. The used one I have is a real rat, lots of corrosion.
Parts for Kias and Scions. 😁Are there any cases where an aftermarket less expensive part is better than the OEM part it replaces? Not functional but better.
