- Joined
- Jun 9, 2021
- Messages
- 139
So this 2012 X3 runs awesome with the MAF disconnected, perfectly smooth idle. Has a small-scale rough idle with it hooked up. Obvious symptom would be an air leak somewhere, but I've smoke tested the intake 3 times and can't find any leaks. It held a lot of pressure before discontinuing the test.
I also replaced the maf with a new BMW part thinking that would fix it. No change.
No codes of any sort. I took it on a 600 mile road trip last month and nothing came up.
I've attached some live data at idle RPM below. Looks like the MAF reading is pretty unstable - any thoughts on this?
