Mopar Oil Filters from the Mopar store
Cost and convenience, and some are worried it might be a warranty issue. I don't have that problem since I stopped buying new cars long ago. Cost and convenience means I purchase most of my oil and filters from Walmart, so what is available there heavily influences what I buy.
Me too. That’s where I get oils with demanding manufacturer approvals such as VW 504 00. Same price as other synthetic oils and Walmart is the lowest.
I did buy filters there in the past but obviously that’s changed. I get them at O’Reilly these days.
I have no concerns about warranty. Nowhere in my owners manual does it say I’m restricted to using what they recommend to preserve my warranty. But like you, everything’s out of warranty now. I drive things to the very end so superior protection and longevity is important to me.
OP could get a Mobil 1 M1-113A at Walmart that would be dramatically superior to the 339.
But he could get the same filter cheaper at Rural King.
Or you can buy a car where the screen doesn’t delaminate and find better uses of your time. You are illustrating what is know as a fool’s errand. Moreover, are you really trying to help people, or bully people into your way of thinking?
Please explain how to tell the future on problems that don’t happen until after 8+ years of purchase? Of course now it’s a known problem but wasn’t when I bought it new.
In the meantime I’ll continue cutting filters and providing reliable information for those that don’t guess on quality.
I would guess also that 99% of filter problems seen by dealers have to do with customer abuse running the filter too long or never changing it.
Pretty much every oil filter found with torn media on this board was ran well within the OEM's recommendation. Lots of oil filters have quality issues that are there right from the factory, or happen with not many miles of use on them.
But on Toyota, which has the best reputation for reliability in the industry, you really think the filter is a risk
If you keep up on the automotive industry, Toyota has had its fair share of issues with various vehicles. Also, there have been Toyota OEM filters here not long ago that have cracked end caps which allow dirty oil to bypass the filter media. Yes, even Toyota oil filters can have quality issues.
People don't guy a vehicle because of a few specific parts are bullet proof - like an oil filter, they buy a vehicle for other many more broad reasons. Once they get it they may have to experience some unforeseen issues, which will of course be fixed under warranty or by a recall. Some people will dump the vehicle and buy something else if it turns out to be a major problem child ... I've been down that road before.
  • Like
Reactions: GW.
Agreed, The closest Rural King to me occasionally has the Mobil 212A and 114A on sale for $7.99, which beats all of the others around me by a fair margin. Ace Hardware sometimes has a $10 off $20 coupon, which can bring the Mobils down to about $10.99 apiece.
Agreed, but the point is most people, the dealer, and your engine will never notice unless someone cuts it open. You could run with an empty can on there and nobody would notice unless you cut it open. Not saying it's ideal, but aside from gross negligence most engines will outlive the rest of the car as long as you do regular oil changes with some sort of filter.
Well you’re the market for those filters then.
  • Like
Reactions: GW.
If the unaware people didn't know what was going on inside the filter, but were then told and shown I'd think most with any mechanical sense at all wouldn't think it's a good thing. Ignorance is bliss in the automotive maintenance world - as long as it's still "running good" all is cool. If it blows-up, then guess something went wrong.
And the only time a dealership might cut open an oil filter is if the engine had some mechanical problem associated with the oiling system, then they would look to see if the filter was the cause. Otherwise the filter just gets chucked or recycled. People that try to justify inefficient filters and filters that have quality issues and show a track record of problems can just keep using them ... not my machine, lol.
My point is we obsess here on BITOG. Like many of you I buy the filters that are well built and have higher efficiency. I recently purchased some Carquest Premiums due to all the good research here. I'm just not convinced oil filters make that much difference. Bob Winters ran a car without a filter and I believe the oil analysis results were the same as with a filter. Is it still possible to find those old threads here?
Probably not. But here is a good example of why a UOA isn’t the proper test, not why oil filters aren’t necessary (or better ones aren’t better).
People keep trying to ascribe significance to a cheap and uncontrolled spectrographic analysis that is completely unwarranted. As Blackstone themselves have noted they have not seen a statistically significant difference in any UOA due to the oil. Those engines are all run with different filters of course. It’s just not the tool for this.
The obsession here is basically what makes people land on good well built higher efficiency oil filters. Nothing wrong with being obsessed to find out what the reality is.
Oil analysis looking at wear particles 5u and smaller will tell you nothing about the performance of the oil filter, especially in one short OCI. You need an ISO 4406 particle count. And the difference in oil cleanliness would be something that makes a difference in mechanical wear and health over the long run for people who might care about that. People that trade cars all the time might not even care about doing the first oil change, lol.
  • Like
Reactions: GW.
Nevertheless it does border on irrationality to continue using something that has been shown to be defective. I used to be a Toyota OEM filter person, but I was shown and comprehended that they did not have the filtering efficiency of other filters. I didn’t make endless comments that “it’s a Toyota so I use their filters” or “it will be good enough to make it through the warranty” or “I don’t want any warranty issues”, or otherwise try and justify what is at its basis an irrational argument. That’s what we have here.
Sometimes if that’s your point then just say, “yeah you’re right but I just want to keep using them anyway”. That would have ended the discussion a long time ago.
What you fail to understand is that the vehicle is under warranty. This is a point about avoiding aggravation, nothing more. And getting a good deal (convenient too) for factory oil filters. If the truck were not under warranty then I would (and likely will) use some of the products recommended here. But if something does fail on the truck I don’t want to have a Lincoln Douglas debate with the dealership about aftermarket parts. I want to hand them the keys and ask them politely to fix the truck Several other owners have chimed in that this happens so the concern is not abstract. Now when the dealers do this, is it fair? Is it right? No, of course not it is pure BS. But to sit here and argue that the factory filter - the same one that is made to the same specs as the rest of the vehicle - is “defective” - and this is your argument - is to take a valid point that there may be other alternatives and stretch it too far. (GW wants to argue that she personally quality tests the other 24,999 parts on the car for better alternatives- her arguments are illogical on their face - if you have to do that much quality control on your own you need to find a different vehicle). And when I call out the BS for what it is, you get either snarky response or one that addresses an argument I am not making.
You are obviously an intelligent person but you might find that your ideas will have greater acceptance here and perhaps in the real world as well if you learned to make arguments in a less belittling manner.
As I stated, I research the parts as they fail. Oil filters are very easy to research here before hand because others post cuts. No one can predict the future of vehicle problems if the vehicle is a new release. Every OEM has winners and losers….
When you recommend an oil filter with known QC problems you’re going to get push back. After all this is an oil filter forum. The sales and rebates section is where you should have posted your “deal”.
https://bobistheoilguy.com/forums/forums/product-rebates-sales-and-promotions.33/
As I also mentioned I would never force someone to do something they aren’t comfortable with. For warranty worriers I have always stated to get all services done at the dealer on time and do not decline any upsells. The real question is why are you working with a dealer that doesn’t honor warranty laws? Do you think they will honor your right to do your own services if they won’t honor your right to use aftermarket parts? You shouldn’t be buying new vehicles from such businesses.
I get that you’re worried about possible confrontation with the dealer. I guess I just was not. I used non-recommended grades of oils and didn’t worry about filter brand.
I did what I thought was best for the engine and for mechanical health, perhaps that’s due to the fact that I keep vehicles for a long time.
Yes it’s a very different mindset when just keeping a vehicle to 100k or less vs keeping a vehicle to well over 200/300k.
