I question the accuracy of these results. The report indicates 66% antifreeze concentration by volume. I seriously doubt FCA would be using this much antifreeze on a factory fill. Usually it is closer to 55% max, not 66.
That is bizarre. I should check the one in my Ram.My 2014 Patriot came with FCA 's new 10 year/150,000 coolant at 64% coolant as measured with my Reichert refractometer.
I'm showing 11.4 quarts is the total capacity. Used a little more than that to flush it.Thanks for the post. I was considering a coolant change on the Caravan, but I'll wait at least a year. Do you know the total coolant capacity on your Jeep.
I’ve seen this occur frequently, actually. If I’m not mistaken the FL22 in the Mazda is a 60/40 split from factory (might be 55/45).That is bizarre. I should check the one in my Ram.
