Mopar OE fill, 86K, 12 Jeep Rubicon Unlimited
Texas
Decided to get an initial coolant sample done on the wife's Jeep. Mileage wise from Mopar the coolant is still good, but age wise I figured it might be time to change but wanted to have an analysis done first to confirm.
  • Like
Reactions: JC1
CA
I question the accuracy of these results. The report indicates 66% antifreeze concentration by volume. I seriously doubt FCA would be using this much antifreeze on a factory fill. Usually it is closer to 55% max, not 66.
MI
My 2014 Patriot came with FCA 's new 10 year/150,000 coolant at 64% coolant as measured with my Reichert refractometer.
  • Like
Reactions: JC1
JC1
Oshawa, Ontario Canada
Thanks for the post. I was considering a coolant change on the Caravan, but I'll wait at least a year. Do you know the total coolant capacity on your Jeep.
MI
My total capacity is 7.2 quarts per the factory service manual. I drained 4 quarts out of the radiator and refilled. My 2014 was actually made in April 2013, approaching 8 years and 100K miles. I advocate the partial drain and fill if you are not changing coolant type. I could have waited another year, but thought now is o.k. since I am only doing a partial replacement. Today's coolants seem to keep the systems so much cleaner than the old high silicate coolants of my youth.
  • Like
Reactions: JC1
MI
I rechecked my notes and it was actually 62%, not 64%. At about 5 years old the overflow tank was down about 6 ounces. After I had already bought OEM coolant to top up, I learned that I could have just added distilled water and still maintain the 50% concentration. I haven't had any recurring coolant loss problems. When I did a radiator drain and fill, I added less coolant % to get the system down closer to 50%.
