My '21 Vauxhall Insignia uses Dexcool in it's little 1.5 3 cylinder diesel (half a 3.0 Duramax). When I bought it (brand new might I add) the coolant level was below minimum mark but in the 10k I've done in it since it hasn't moved or gone down (or up for that matter). I decided to finally top it up last weekend and used Comma G30 (see link below). I figured it's an OAT coolant like Dexcool and as Dexcool is considered a 'universal' coolant these days it would be absolutley fine. But now I'm doubting myself. Anyone confirm if this is likely to have any adverse issues?
Xstream® G30® Antifreeze & Coolant Concentrate : Manufacturer Approved Antifreeze & Coolants : Products Guide : Moove Lubricants Limited
Access the full description, specifications, application recommendations, Material Safety Data Sheet and Technical Data Sheet for Xstream® G30® Antifreeze & Coolant Concentrate from Comma.
www.commaoil.com
