Originally Posted By: FL_Rob
140C is about 280F ,with regular daily driving, does the avg oil even get that hot? I dont have an actual temp guage just typical GM 100-260 coolant temp. It dosen't look like that form of moly even kicks-in below that 280F point or am I not decifering this correctly?
Although oil temps as a whole normally wouldn't rise much above 100°C, there are hotter and cooler places within the engine that the oil passes over. I'm assuming that the higher temperature places within the engine are where the benefits of a good moly coating are most needed.
