A patent, http://images.freepatentsonline.com/5942475.html, by EXXON CHEMICAL PATENTS INC (US) filed in 1997 states:
Quote:
Moreover, the complex alcohol esters of the present invention eliminate the necessity of adding costly molybdenum to the lubricating oil in order to satisfy the percent fuel economy improvement which is required under the proposed GF-3 specifications. To the contrary, if conventional molybdenum additives are added to the lubricating oil comprising complex alcohol esters the data set forth herein clearly demonstrates that the resulting product has reduced percent fuel economy improvement than lubricating oils using complex alcohol esters or molybdenum alone. It is believed that the molybdenum and complex alcohol esters compete for surface cites, thus reducing the effect on the friction and wear performance of the lubricating oil.
Mixing things can cause unexpected interactions and performance. In this case, it was surface competition between moly and the esters. This is not a new concept, it's just another example of a known (by you knowledgable members) concept.
Here's some data from the patent that I've made more readable and added the comment on viscosity. It's impressive what this CALE ester did.
Quote:
(M 111 Test Result) Oil Viscosity Grade, % CALE, % FEI**, HTHS
______________________________________
Reference 5W20..0%...2.4-2.8%..2.7 cP (thinnest by far)
Ultron* 5W30.....5%....2.0%.....3.07 cP
Ultron* 5W30.....10%...2.5%.....3.07 cP
Ultron* 5W30.....15%...3.5%.....3.08 cP
*Ultron is a polyalphaolefin. **designates percent fuel economy improvement. CALE is an ester formed from the reaction product of trimethylol propane, adipic acid and isodecyl alcohol having a total acid number of 1.0, a hydroxyl number of 18 mg (KOH/gram sample), a metal (titanium) content of 1.7 ppm and a Flash Point of 465° F.
As demonstrated above..., blending of other hydrocarbon-based or synthetic oils with the complex alcohol ester according to the present invention results in a dramatic increase in the percent fuel economy improvement compared to the hydrocarbon-based or synthetic oils along or in combination with other ester basestocks.
Here's an interesting later comment about greasiness provided by the esters:
Quote:
The complex alcohol esters of the present invention demonstrated very good lubricity, much better than their wear characteristics. It is believed that these complex alcohol esters create a very "greasy" surface, but the thickness of the layer is too thin to give a proportionate decrease in wear. The very heavy components most likely impart very good wear and lubricity characteristics, but, at least in the case of wear, are diluted to some extent by the very light components.
