Originally Posted By: MolaKule
Quote:
As we developed the Mobil 1 ESP
technology we found that combining Visom with PAO could deliver a formulation of equivalent performance to an all PAO formulation.
BTW, I do NOT work for EXOM nor do I have any interests in EXOM, Amsoil, etc.
I think what they are saying is, due to variability and short supply of expensive PAO, they will blend their GroupIII Visom with PAO, and then use GTL when that GroupIII+ supply increases.
As far as transparency,
Quote:
With the exception of Germany, this reformulation will be invisible to consumers and B2B customers.
In Germany, you can only claim to be a synthetic if you have a high percentage base oil of PAO and or Esters.
In NA, you can still claim a synthetic if you use GroupIII, PAO, and AN's, and esters, due to the Castrol/Mobil fiasco.
I mentioned this patent years ago on Bitog:
http://www.patentstorm.us/patents/6713438/fulltext.html
Reading the patent, I happened upon this phrase:
it would be desirable to provide lubricant compositions which can function effectively under high temperature conditions and which possess good Theological properties to provide adequate. film thickness
The implications of this statement are staggering:
Is Mobil using holy water to make their lubricants?
Does this mean if we have faith in our oil, it will provide good protection, regardless of its HTHS?
Who is the patron saint of motor oil?
(OK, I'm milking it I know, but some patent attorney trusted his spell-checker, and it didn't weed out Theological and replace it with Rheological.)
