- Joined
- Jun 26, 2023
- Messages
- 350
Just a joke, man. Some of you guys need to lighten up or spend less time on here or something. Jc.Isn't that an improvement? However, the actual change was to take it up to 26 mpg. But, thanks for your input.
That was me~!I know 1 Member on here who has no problem using a Thinner Oil. LOL
When did that start happening?Thinner motor oil flows more easily than thick oil, and moves more quickly to every part of you engine at "cold start". I think that this is a critical consideration since the greatest amount of engine wear occurs at start up.
That's great, I love it.When did that start happening?
0W-0.5 will be out next year.No such thing possible. Kinda like, you can get close to the speed of light, but can never go as fast as the speed of light.
I did not realize that 5W-20 oils existed in 1965?I have used 5W-20 motor oil in every vehicle I've ever owned starting with a new Dodge Polara 500 in 1965 with a 383 cu in motor.
I was skeptical, never remember seeing 5w-20 before about 15 years ago. 10w-20 yes, but not 5w-20. I searched and found a factory service manual for a 1965 Mustang. For temps below -10F Ford recommended 5W-20, above 10w-30, so yes, definitely existed by 1965.I did not realize that 5W-20 oils existed in 1965?
I was too (should have added a sarcasm emoji to my post) because I knew that it did not exist in 1965. I have never seen an example of it in production from back then despite the OM. 20/20W did...I was skeptical, never remember seeing 5w-20 before about 15 years ago. 10w-20 yes, but not 5w-20. I searched and found a factory service manual for a 1965 Mustang. For temps below -10F Ford recommended 5W-20, above 10w-30, so yes, definitely existed by 1965.
That jogged my memory, the original Mobil 1 in 1974 was 5w-20.
https://www.mobil.com/en/lubricants/about-us/mobil-1/one-great-oil-one-great-story
Here is a post from 2009.I did not realize that 5W-20 oils existed in 1965?
You mean lower than 0W0 aka straight 0W? How is this even possible, the weight can go below a 0?0W-0.5 will be out next year.
Well first off because the winter ratings are not a weight. And secondly because the numbers don’t mean anything, they are just designations for specific performance targets. I think it would be better if they weren’t numbers so people wouldn’t be so confused by them.You mean lower than 0W0 aka straight 0W? How is this even possible, the weight can go below a 0?
I thought it was circa 1974 via Mobil 1?Here is a post from 2009.
5w20 was originally not synthetic.How Long Has 5w20 Been Around?
I never even heard of 5w20 until my Ford dealer starting pushing it down the customers throat somewhere around 2002...I don't ever recall seeing 5w20 on store shelves until 2002...The Ford dealer put pictures of the 5w20 everywhere in the service area and even handed everyone that came in to the...bobistheoilguy.com
In the US it was. A year earlier in some other markets:I thought it was circa 1974 via Mobil 1?
I'm using Royal Purple XPR 0w8 in my Lexus ES300h right now and I absolutely hate it. Too much valve train clatter and the lifter tick is louder. Hate it so much I'm contemplating changing it out at 5000 miles. I only have 1500 miles on this oil and it's too expensive to chuck it this early.
I am a Royal Purple user and 0w8 only comes in XPR. I am also a fan of their synerlec additive and XPR oils have the most synerlec in it.Why would you use a non-API drag racing oil in a street car?
It's suitable for street cars. It's has higher amounts of ZDDP , moly and detergents as well. My last oil was Royal Purple XPR 0w20 and there is a UOA here about it.I would be highly skeptical of using an oil like this for 5k. What does RP say about it?
