I took a static compression reading before I started with the mobil mx2t 225lbs hot. 35hrs + later I took a reading yesterday I am still reading 225lbs. 36:1 av fuel 100LL. I pulled my pipe just to get a look at the exhaust side of the piston and rings. No blow by what so ever.I had 20 hrs on the top end before I switched to the mx2t. My compression with a fresh top end is 230lbs. The main powervalve had no carbon when looking through the exhaust my powervalves are ''going to be easy to strip compared to the maxima 927. 927 can lubricate and lubricate well,but the powervalves are a bugger to remove. I like a clean motor,but I also like a well lubricated motor. I will see how the mx2t compares to the 927 lubricating wise.
Keith.
"LET'S JUST RIDE".
00,03 KX250
[ August 29, 2003, 11:14 AM: Message edited by: KX 455 ]
