Originally Posted By: dole
1# AP 5W-30, 11.7 @100C, but HTHS only 3.0, comparing shell 5W-30, 12@100C, BUT HTHS 3.5. Huge difference, why is it so? Mobil formulate it on purpose?
Isn't it true that higher HTHS is a better thing?
At least in Europe, we generally don't trust low HTHS. For good reasons, VW and Ford used to spec low-HTHS oils on some engines - with desastrous results.
The 1.0 ecoboost seems to do fine, but that engine was desgned for this lubricant. But in the past, Ford used to prescribe low-HTHS oils to Volvo engines that were clearly NOT designed to cope with them. VW first generation of long-life oils also were reduced HTHS, and after a short while they pulled back and returned to HTHS>3.5.
That is why ACEA A1/B1, A5/B5 and C2 generally have a
very bad name amonst car enthusiasts here.
Nowadays you see even several european manufacturers push low viscosity oils. As CO2 targets become much harder to reach, durability becomes less important than fuel economy.
Now, that does not mean that an engine necessarily wears out faster or fails catastrophically with low HTHS oils. A friend of mine who works in the automotive industry used to run engine tests (with teardowns) and reported some of the tests with the best (i.e. least) wear were run with 0w-20 - even though oil pressures were dangerously low. Still, next to no wear. But then, there were other 0w-20 wich produced the worst wear. With thicker oils, you can separate moving parts by the oil film - with thinner oils, you NEED perfect temperature management - and you have to rely entirely on the additive package to control wear. Thick oils is physics, thin oils is witchcraft.
I won't touch a low-HTHS oil with a ten-foot pole. That is, unless I'd own an engine specifically designed for it, such as the 1.0 ecoboost. I'd never run a low-HTHS oil in an engine that was merely back-specced to do so.
