Quote:
Unintentionally (nevertheless probably) opening another can of worms here, but just how certain is anyone that a GTL base oil (described by some sources online as a "super" Group III base oil due to its lack of polycyclic aromatics, wax, and freedom from metal, nitrogen, and sulfur contamination) isn't perhaps what Mobil is loading into Mobil 1 EP?
We don't know wher the M1 in the test came from either. Was it new stock bought off the shelf or supplied by mobil?Quote:
There's just too much unknown to say that with any confidence....
Quote:
Well, I know in 9-5s, the issue with 30 weight M1 wasn't deposits (at 5k), it was oil pressure. Honda, I'm sure, was just trying to stay on the thin side of things.
Quote:
The point was people are scared to use it in applications that they had no problems using M-1 in the past. Group III and PAO performance as baseoils are closer than ever. The truth be told I have no problems using M-1 for the same applications that it was always recommended for.
Quote:
Quote:
This is an advertisement not a test.
LOL- yea really. Sorry I want the last 2 minutes of my life back.
Quote:
I would not use M1 xW-30 in turbo engines because of warnings from Mercedes:
"some oils which are not recommended:
Mobil 1 SuperSyn 0W-30 SL/SJ/CF A1/B1/A5 9.7 doesn't meet 229.1 nor ACEA A2 or A3
Mobil 1 SuperSyn 5W-30 SL/SJ/CF A1/B1/A5 9.8 doesn't meet 229.1 nor ACEA A2 or A3
Mobil 1 SuperSyn 10W-30 SL/SJ/CF A1/B1/A5 10.1 doesn't meet 229.1 nor ACEA A2 or A3
These 3 oils do not meet MB spec of > 3.5 cP for high temperature high shear strength."
xW-30 oils that meets ACEA A3/B3/B4 and MB 229.5 and available in USA:
Pennzoil European Formula Ultra 5W-30
Quaker State European Formula Ultra 5W-30
Castrol Syntec European Formula 0W-30
Elf Excellium 0W-30
Source: http://www.whnet.com/4x4/oil.html
Quote:
Interesting... that said, our 2.0L ecotec derived engines dont hve any issue with pressure of 30wt oils... yet M1 5w-30 is in no way reccomended whatsoever for use in those engines. At the same time, the 9-3 is designed for up to 18k mile OCIs, but then again, acuras are likely specced for what? 10k mile OCIs with a filter change every other time? Not that different, in the big scheme of things, considering that most saabs only go 12-15k on their oil change interval.
Im not sure that Id use M1 in my 9-3 one way or another, due to its lack of an A3 rating, which in my owner's manual, is claimed to be accpetable if top-up is necessary and a non GM-LL-025-A oil is not available. Though M1 is good oil, and works great in certain (many) applications. leaving the value analysis out of it, if the GIII,IV,V mix is doing great per UOA, in whatever engine, then all is well... if compromises are made, then we must look elsewhere - this is the case for any oil.
For us, M1 isnt the right choice one way or another... but in, for example, our acura, regardless of the value formula, if UOAs keep looking good (as they do), we will keep using it there...
JMH
Quote:
Most folks I know who ran 5W30/10W30 Full synth M1 (back in the day) for decent intervals on the earlier 900s and 9000s weren't having any problems.
Quote:
It's an advertisement of a test performed by Honda. Take it for what it's worth.
BTW, the test was done by Honda not Mobil.
