Mobil 1 FS X2 5w50 vs Supercar 5w50?
One is mid/low SAP one is full.
ESP/Super Car oils - mid SAP.
FS - Full SAP.
Mobil's made a bit of mess with multiple 0w40s now but niche oils are the thing these days....
Thanks! Since the FS can be found for $7ish a quart and Supercar is $13ish it seems like any car that doesn’t need the lower SAPS of Supercar could just happily use FS X2.
It’s interesting that both the pour point is lower and V@100c is higher on the Supercar oil.
Again it would be nice to know which product Mobil themselves said is the same as m1 5w50 supercar and advertised such to every owner in that literature that was received.
The ad said same tech - not the exact same oil. In contrast, the 0w-40 was exactly the same as ESP:
I know that's my picture from Mobil 1 handouts I received when meeting with their engineers
They state the same for both...
Adding this VOA comparison for discussion point. VOAs courtesy of PZEV.
Supercar looks like a higher ZDDP oil with less detergents.
Any reason these oils aren't essentally interchangeable? Which one is the higher quality base oil and better for wear protection?
FS - Full SAP.
One question I have is how can the mid Saps oil (Supercar 5w50) have higher ZDDP than the Full Sap FS? Is only the 0w40 oil the mid saps version?
By the VOA, the Supercar 5W-50 looks like midSAPS detergent/TBN level with Fricton reducers/ZDDP levels higher than a typical fullSAPS formulation.
I guess, LT6 valvetrain being all mechanical with no hydraulic compensation requires the higher organic ZDDP formulation to preserve the finger followers and Cams. The Porsche GT engines have similar valvetrain and I won't be suprised if the newer M1 CGT 0W-40 formulation is somewhat similar to 5W-50 supercar.
Compared to the FS X2, the Supercar MSDS shows a GTL base and the additive pack ingredients look like the ones used in a ACEA C3/ESP formulations.
The FS has group 2 ish base with standard ZDDP
Compared to the FS X2, the Supercar MSDS shows a GTL base and the additive pack ingredients look like the ones used in a ACEA C3 formulation.
Theres a VOA for c40 gt already. It has esp x3 add pack
I thought Exxon only made Group1, Group2/2+, Group3+?(Visom) and synthetic base stocks based on their product offerings
https://www.exxonmobil.com/en/basestocks/products
I don't know if they get Group 3 from SK/Chevron or somewhere else and have the CAS# in question.
Looking at MSDS sheets across manufacturers for base stocks, synthetic stocks and oil lines, This classification makes sense for me.
I get that there are always exceptions to the CAS classification based on manufacturing process and the final quality of the product matters more than anything else.
Having said that, I expect more from an M1 FS line.
Group 1CAS#64742-65-0Solvent Dewaxed Heavy Paraffinic DistillateExxon Americas CORE?
Group 2/2+CAS#64742-54-7Severly Hydrotreated Heavy Paraffanic DistillateExxon EHC, Some Yubase oils (group3)
Group 3CAS#72623-8X-1Lubricating oils, hydrotreated CXX-XX, neutral oilbasedChevron Nexbase (group 3)
Group 3+?CAS#64742-71-8Catalytic Dewaxed Light Paraffinic OilExxon Visom 4
GTLCAS#848301-69-9Distillates, Heavy, C18-50 - Branched, Cyclic and Linear (Fischer-TropschShell GTL
PAO/mPAOCAS#68037-01-4
CAS#68649-12-7
1-Decene Homopolymer/Tetramer/Trimer etc.., HydrogenatedExxon SpectraSYN products
References:
Exxon basestocks: https://www.exxonmobil.com/en/basestocks/products
Exxon MSDS search: https://www.msds.exxonmobil.com/psims.aspx
Chevron basestocks: https://chevronbaseoils.my.site.com/s/typicals
Chevron MSDS search: https://cglapps.chevron.com/msdspds/SDSPage.aspx?directSDSLink=true
Shell GTL: https://www.shell.us/business-custo...8/product-stewardship-lubes-gtl-base-oils.pdf
SK's basestocks : https://www.skenmove.com/business/base_oil
YUBASE MSDS: http://www.yubase.com/product/msds
Mobil 1 Super 10W-40 blend for example:
Mix of Group 1 + Group 2
Here in Europe until last year we still had the X1 version, which was mostly GTL and PAO with a dash of Ester, the X2 version is mostly if not all Group 3 / 3+ which is kind of a bummer, although it is API SP now with less Calcium and more Magnesium.
