Mobil 1 EP vs Pennzoil Platinum 0w-20 NOACK
Originally Posted by painfx
Hi.
I am comparing those 2 because they are easily found at Walmart. I noticed that although people are saying Mobil 1 EP is a PAO oil, but I still find it burns oils. Besides the fact that it can go longer OCI, seeing it burning oil, is a dislike for me. But I know I can't go wrong with either. I am just here want to hear opinions on what others have to say.
I chose PPPP is because it is cheaper and I do OCI at 5k. Wanted to see how great PPPP (GTL) compared to the oil school PAO Mobil 1.
Thank you.
OIl burning is an engine-repair issue and is not directly related to the base-oil type or quality. The quality of the oil will not make a difference unless the NOACK is really bad or the KV and/or HTHSV viscosities are off the specs. You can experiment with thicker oil to reduce the consumption though.
If price is a concern, the likely GTL-based Walmart Super Tech High Mileage 0W-20 Full Synthetic is as good as or probably better than the Pennzoil Platinum 0W-20 and at a much lower cost.
The best overall 0W-20 you can buy is Mobil 1 Extended Protection 0W-20.
Here is my personals ratings based on the simultaneous consideration of CCS and NOACK, which infers to some extent the base-oil quality. Note that it doesn't take the additive package into account. Top-rated oils have PAO, followed by GTL-containing oils and then Group III oils. The Genuine Nissan and Genuine Toyota are GTL-based but they later switched the Toyota back to Group III. The Super Tech is likely GTL-based.
Code
Rank BOQI DV-35 NOACK Date purchased Oil
1 > 85 ? ? N/A Mobil 1 Extended protection 0W-20
2 84.3 4,110 10.10 2014/02/16 Mobil1 Synthetic API SN, ILSAC GF-5, SAE 0W-20 motor oil
3 83.3 3,928 10.70 2015/12/28 Mobil 1 Full Synthetic SAE 0W-20 dexos1
4 81.9 4,316 9.90 2018/01/25 Genuine Nissan Full Synthetic SAE 0W-20 Motor Oil
5 80.4 5,122 8.50 Amsoil PDS AMSOIL Signature Series Synthetic Motor Oil 0W-20 (ASM)
6 78.2 4,182 10.70 2017/03/06 Mobil 1 Advanced Fuel Economy Full Synthetic SAE 0W-20 dexos1
7 66.1 4,102 12.90 2018/01/24 Genuine Toyota Synthetic SAE 0W-20
8 59.0 5,929 10.00 2018/03/12 SuperTech High Mileage Full Synthetic SAE 0W-20 Motor Oil
9 57.8 5,884 10.30 2017/03/06 Pennzoil Platinum Full Synthetic with PurePlus� Technology SAE 0W-20 dexos1
10 57.1 6,068 10.10 2015/12/28 Pennzoil Platinum Full Synthetic SAE 0W-20 dexos1
11 54.9 5,958 10.70 2014/02/06 Quaker State Synthetic API SN, ILSAC GF-5, SAE 0W-20 motor oil
12 54.0 5,448 11.90 2015/04/01 Beck/Arnley Premium OE Fully Synthetic SAE 0W-20
13 54.0 5,949 10.90 2018/03/12 Royal Purple Synthetic Oil SAE 0W-20 High Performance Motor Oil
14 53.2 5,721 11.50 2015/12/28 Valvoline Full Synthetic SYNPower SAE 0W-20
15 53.0 5,006 13.20 2015/12/28 SuperS SuperSyn Full Synthetic SAE 0W-20
16 51.9 5,819 11.60 2017/03/06 Valvoline Full Synthetic SYNPower SAE 0W-20 dexos1
17 51.7 5,642 12.00 2018/01/24 ACDelco Synthetic SAE 0W-20
18 51.2 5,342 12.80 2017/12/09 Honda Full Synthetic SAE 0W-20 Motor Oil
19 49.8 5,537 12.70 2015/12/28 Castrol Edge Full Synthetic SAE 0W-20 dexos1
20 49.5 5,996 11.80 2017/03/07 O'Reilly SAE 0W-20 Full Synthetic dexos1 Motor Oil
21 48.6 5,451 13.20 2014/08/14 Castrol Edge Synthetic Motor Oil API SN, ILSAC GF-5, SAE 0W-20 motor oil
22 47.6 5,658 13.00 2015/07/27 STARFIRE SAE 0W-20 Full Synthetic dexos1
23 47.2 5,657 13.10 2014/02/07 Pronto Supreme API SN, ILSAC GF-5, SAE 0W-20 motor oil
24 47.2 4,981 14.90 2014/08/25 Starfire Motor Oil API SN, ILSAC GF-5, SAE 0W-20 motor oil
25 46.2 5,786 13.10 2015/12/28 ProLine Full Synthetic SAE 0W-20 dexos1
26 45.6 5,113 15.00 2014/12/01 i-Sint XL 4AM Synthetic SAE 0W-20, API SN, ILSAC GF-5
27 44.9 5,647 13.80 2017/12/09 i-Sint XL 4AM Synthetic Engine Oil SAE 0W-20
28 43.5 6,138 13.10 2017/03/06 STP SYN Full Synthetic SAE 0W-20 dexos1
29 43.1 5,723 14.20 2016/01/25 AMSOIL Synthetic OE SAE 0W-20 Motor Oil
30 41.8 5,814 14.40 2014/02/07 MAG1 API SN, ILSAC GF-5, SAE 0W-20 motor oil
31 39.7 6,163 14.30 2014/08/11 Federated Motor Oil API SN, ILSAC GF-5, SAE 0W-20 motor oil
List of 0W-20 oils by base-oil-quality index (BOQI): 2018
