Originally Posted By: NHHEMI
You see what you post vastly different than I do reading it. Perhaps you don't convey your actual intent well? You come across, most times, as someone with a bias against RP who takes every opportunity to belittle their product.
Or perhaps you are overly sensitive to what I'm saying or THINK I'm saying, and subsequently don't necessary read what I'm saying in the manner in which I meant it. I DO try and be as clear as possible.
Quote:
RP does not just go the the oil additive store and grab what they want and then go home and throw it into a bottle as you are basically saying here.
No, that's not what I'm saying at all.
Quote:
This isn't buying a bottle of Prego at the supermarket and going home and dumping it in a pot and saying you made homemade spaghetti sauce when dinner is served. That is how you make it sound with RP.
No, it isn't.
Quote:
In otherwords their product is actually all someone else's stuff they just mix together and throw in a bottle without RP actually doing anything with what they buy to come up with a unique product.
No, I'm not saying that. I'm saying that as a BLENDER, they are more limited in their choice of what components they have available to them compared to the majors. This is because they don't have the ability to make their own components if they need something that doesn't exist like say a special high VI base oil.
Quote:
They obviously buy basestock as they are not a refiner and they may well buy some additives as you say. However, they do a lot of formulating on their own and a lot of what goes into the bottle is not something that comes from a supplier. RP's Synerlac is something done in house. It may be made up of items purchased but it is what they do with it that gives the end result. Frankly, most oil suppliers fall into this but do you question them and discredit their products as well?
1. You sort of contradict yourself above. If the item is purchased, then it comes from a supplier.
2. I am NOT trying to discredit them! I've stated that companies like XOM have the CAPABILITY to make the "best" products because they can MAKE their own components! And this is SPECIFICALLY why I mentioned race lube relationships, because I think THOSE situations are often "max effort".
This does NOT mean that:
A) Blenders like Ashland, RP, AMSOIL, Redline...etc may not put more effort into specific grades of their lubes, or lubes for specific applications (see RP's industrial lubes as Garak mentioned).
B) That the majors are the "best" across the board. Having the capability of being the best does not mean that you ARE the best! Particular at EVERYTHING. As I mentioned earlier, and was echo'd by others: Mobil 1 0w40 is their "flagship" oil, and likely a very good example of their "best" effort. That doesn't mean that their 10w30 is!
Quote:
Believe what you wish I really could care less. I am only sensitive when people go out of their way to discredit RP for reasons unrelated to an actual bad experience using it or some legit reason that does not require use. Sadly it happens on this site far too often. I really don't care if people use it or even like it just be civil and fair.
Please take a look back through the thread at my first few posts. I did nothing to tear down RP and only stated that the AFE had a higher VI. It wasn't until this post by deven:
Quote:
Between those two oils I will choose Royal Purple all the time and all day long. Seen race engines at my shop that have run M1 and RP and every SINGLE time there is less wear with RP than M1 fed cars.
That I made a point about bringing up Mobil's OEM race program use, and things quickly went downhill from there.
Quote:
There are a LOT of oils/oil mfg's I dislike but I do not purposely go out of my way to beat up on them the way you and other RP detractors do( yes, that is what you are even if you won't admit to it and use their ATF ).
You know, I actually don't dislike RP. That's why I'm using their ATF. You won't find a SINGLE BP product in my house. You won't find SOPUS products, or any Ashland products. I don't use them.
I responded to a CLAIM made in this thread about the performance of one of the brands of oil I use. There was no mentioned of grade used, whether it was race oil or PCMO, HDEO....etc. It was just a blanket bomb dropping and I responded to it.
Quote:
I actually dislike ExxonMobil with a passion and think their oils are mediocre at best but do I run around in every M1 post saying that? NO! I generally just avoid the post. "IF" there is a specific question about M1 tied into a post about other oils I might mention it is not my choice but I don't berate and belittle those who use it. Even in this thread I did not belittle M1. Rather I questioned the reasons some of you were using to claim it as the best ever.
But we weren't claiming it is the "best ever", simply that the company who makes it has the CAPABILITY to make the best lubes due to their size and scope.
Quote:
The anti RP crowd( many of whom have never even used it )feel the need to talk it down in every thread where it is mentioned however. The second RP is mentioned you can count the seconds until someone will feel the need to start trashing it in some way or form. GUARATEED! In some way they will speak negative about it. It is foolish and frankly annoying. THAT is why I respond at times as if I am sensitve.
So then you can understand why I responded to the M1 claim, right? My response is based on the same defence mechanism as your own. Nobody likes to see a product they've used extensively and for a very long time talked down, particularly in the vague and often aloof fashion that is quite common on here.
Quote:
In this thread in particular all people needed to do was simply pick - RP or M1 and leave it at that.
Threads never go that way on here, you know that
Quote:
If a certain spec is needed for say warranty that RP does not cover fine say that and leave it at that. If M1 is actually certified to the spec and we don't know about RP that doesn't mean RP doesn't or can't meet the spec either. It just means their oil was not tested but people will try and say because MI has the cert that makes it better which we all know, in truth, is a bogus statement.
Not necessarily. While some of the certs and approvals may not be all that meaningful, I think with some of the high-end certs and approvals (again, see M1 0w40), you ARE being given a guarantee of performance.
Quote:
If you have used one or the other in the specific vehicle( there was one mentioned in the original post right? )say I used RP or M1 and it did good or bad in the application. Basically speak to the question and leave out the brand bashing.
Instead it gets turned into M1 is the best ever and is used FF and in race teams, and it carries every spec cert under the sun as if that makes it the actual best oil, while RP is just some backwoods company who buys premade ingredients for their oils and just mixes it all together and bottles it. You personally made it sound like RP is the housewife who bought bottled sauce and tried to pass it off as homemade. That is just untrue. The constant RP bashing on this site just gets old. I know M1 gets it's share of bashing too so I believe the M1 fans know what I mean. If they do they should try and not do it with RP.
Yes, I DO know what you mean, and I'm sorry you took what I stated in the manner in which you did. That was NOT my intent. I was validating XOM's capabilities by demonstrating their manufacturer relationships, that is not the same thing as tearing down RP, even if it ended up being viewed in that way.
Quote:
Bottom line is stick to the topic and leave out the rants and rhetoric. If you don't use a product or know how it is made don't speculate and stir up a hornets nest and then whine when people call you out.
I am done with this and I hope you can be as well. Let the thread go back to the actual topic.
But this kinda is the topic
Either oil is going to work just fine in this application. But that's been stated a gazillion times at this point.
