I have a 2014 Cadillac CTS-V with the manual trans (GM LSA Engine) that has 4,000 miles on it currently. At 1,754 miles on the engine, I drained the factory fill AC Delco Synthetic Blend and removed the GM factory blue PF48 filter and filled the crankcase with Mobil 1 5W30 and I installed an Amsoil EA15K50 oil filter. When I drained the factory oil, it was blacker than tar!
I noticed that the oil got dark very quickly and continues to get darker and darker every time I check the level which is every other day due to the consumption issues I have been experiencing. I want to make sure the oil level is always full and I top off when necessary with the same Mobil 1 5W30. Is the getting black just because the engine was new when I changed the oil and the engine is breaking in and causing the color of the oil to get dark so fast or is this just a characteristic of the GM LSA engine? Is it the oil and filter I am using? I have a little over 2,000 miles on the oil and I can't believe it is so dark already. Is it due to how hard I have been driving it?
Any thoughts?
