Originally Posted By: SteveSRT8
Originally Posted By: Noey
If 5 pages isn't the definition of circle jerk, I don't know what is.
You can drive your new car anyway you like, and you can believe what you want. However, the simple fact that the car is gulping down oil indicates that your particular set of beliefs are erroneous. You're beating on a new engine and the result is that you've broken something. it's real easy for the peanut gallery to offer encouragement and advice. but absent any actual qualifications, only a fool listens most to the advice that agrees with their preconceptions.
A performance car doesnt need performance driving when new. An infant..even Einstein...didnt start out with a steady diet of spinach and steak. back off...2500 miles is hardly "broken in"...and see if the change in your adolescent behavior changes your engine's response. If not, take it to another Cadillac dealer and let them take a look.
geez...
You may wish to explain this very common refrain in mine and many other cars owner's manual: "full throttle operation is beneficial to engine break in".
The number one Ford performance guru in the country takes brand new engines, warms them up, then does several FULL THROTTLE pulls to redline on 10W oil.
My BIL is a third gen machinist who works on mega expensive hot rods all the time. His advice? Drive it hard when new for best performance, less blow by, and longer engine life.
Then there's others. Lots of them.
I have an entire fleet of V8 powered service trucks and a few cars/boats,toys as well. Not a single one burns oil between servicings. One has 200k miles. Several are at or near 100k miles.
All were broken in at higher speeds in the upper gears. It's only worked for 43 years...
Yeah? So, how do you explain gulping down a quart every thousand miles?
People once believed the world was flat, too. They were convinced, after all, they always experienced the world as flat. That's until someone showed them it wasn't so.
The guys has a problem with his engine, likely caused by his adolescent response to having a zoom zoom car. Most folks don't run a performance car flat out on a consistent basis until everything has seated. That some have gotten away with this isn't the issue, it's that he apparently has not.
The safe, even *Gasp!* scientific way of demonstrating this..if the damage isn't permanent, which we can find after the inevitable tear down... is to back off for a while and see what happens.
What exactly is the problem with that?
