Mobil 1, 10w-30, 10k; Honda Fit 2007, 97k milles
Originally Posted By: skyship
Originally Posted By: buster
Other than the moly, it looks like the current formula. Definitely doesn't look like it's from 6-7 years ago.
Some of the M1 oils do not contain Moly, BUT you always get a few ppm from previous oils or assembly lubes etc. Moly doesn't burn off so you can see roughly what was in the virgin oil from a UOA.
Kinda makes your quote of all major oil companies not using moly anymore. You even posted that Mobil and Amsoil didn't use it,yet Amsoil just started in the past few years and Mobil always has.
More skyship wisdom.
Can you tell me which M1 oils do not use moly?
Yeah tig is right, they have all had moly for years. All M1 grades.
There is a UOA showing the use of Mobil Delvac 1 that has no Moly and another for M1 5/40 diesel turbo diesel and that does not have Moly either. Most big oil companies make top of the range G4 synthetic oils that have no Moly in them, but most of the cheaper HC synthetics, part synthetics and conventional oils do contain Moly.
Here is the VOA of Mobil 5000, another Moly free oil:
Mobil Moly free oil.
Delvac 1:
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1123910#Post1123910
Mobil 1 15w50:
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2862511#Post2862511
Mobil 1 0w40:
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2824329#Post2824329
The fact that there is moly in M1 0w-40, let alone the other two, tosses your argument right out the window.
Mobil 5000 isn't a synthetic, and isn't a Mobil 1 grade. Making your reply to buster pointless.
