Mobil 1 0W30 AFE 6020 Miles 06 Toyota Tacoma V6
New Mexico
This is the fourth UOA I have run on my 2006 Toyota Tacoma 1GR-FE 4.0L V6 Doublecab.
This UOA was done at 354,358 miles on 3/23/14 with 6020 miles on oil. Previous oil change at 348,338 miles was performed on 01/25/14.
This report was performed primarily as periodic check for engine issues. I changed the oil to Mobil 1 0W30 AFE during the winter months and this report looks at that. All previous oil used in this truck has been Mobil 1, three fills Mobil 1 AFE 0W30 all other fills Mobil 1 EP 5W30.
I changed back to Mobil 1 5W30 EP during the last change.
Discussion of previous UOA's on this truck were in these three threads:
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2948065
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2921817
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2784866
I am including the UOA in both an image and a code block.
Code:
OIL M1 AFE 0W30 M1 AFE 0W30 M1 EP 5W30 M1 EP 5W30
MILES IN USE 6,020 7,014 11,604 7,090
MILES 354,358 319,459 312,445 300,841
SAMPLE TAKEN 4/22/14 03/16/13 12/30/12 10/21/12
ALUMINUM 3 4 3 3
CHROMIUM 0 1 1 0
IRON 11 20 19 14
COPPER 1 1 1 1
LEAD 0 0 0 1
TIN 0 1 0 0
MOLYBDENUM 66 73 72 87
NICKEL 0 0 1 0
MANGANESE 0 0 0 0
SILVER 0 0 0 0
TITANIUM 0 0 0 0
POTASSIUM 3 2 3 0
BORON 37 36 32 43
SILICON 11 12 13 17
SODIUM 8 10 8 6
CALCIUM 937 940 1045 1136
MAGNESIUM 695 726 736 813
PHOSPHORUS 528 600 653 733
ZINC 579 708 765 967
BARIUM 0 0 0 1
SUS Viscosity @ 210°F 57.2 58.7 58.9 57.9
cSt Viscosity @ 100°C 9.41 9.86 9.90 9.61
Flashpoint in °F 370 390 430 425
Fuel % 0.8
Antifreeze % 0.0 0.0 0.0 0.0
Water % 0.0 0.0 0.0 0.0
Insolubles % 0.1 0.3 0.3 0.3
TBN 2.3 1.8 1.8 2.2
Originally Posted By: GutsyGecko
TBN of 2.3 and recommending another 3k miles?
2.3 is a lot of additive for 6k run. It doesn't drop in a linear fashion so it would be fine.
Nice report - now that the 5W-30 M1 EP price has dropped, I'd probably just stick with that and change it at 11 or 12k. Man, you really do a lot of miles. How's the rest of the truck holding up?
The truck is in great shape.
Wow!354k miles?a v6 and low metal number like this ?v engine usually have higher metal value.will probably use this oil next since i want a 0w30 next.
