Mobil 1 0W-40, 5,600 miles, 2008 Porsche Cayman S
Here
Here's my second analysis. It looks good, nothing to worry about. The fuel dilution is gone, it was either caused by short trips (didn't have a chance to burn off) or my rings have finally seated.
What's copper from? Bearings?
Here's the discussion on the original sample:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2335002
Code:
OIL M1 0W-40 M1 0W-40
MILES IN USE 2,600 5,615
MILES 14,600k 23,000k
SAMPLE TAKEN 7/23/11 3/10/13
ALUMINUM 4 4
CHROMIUM 0 1
IRON 11 15
COPPER 15 14
LEAD 4 4
TIN 2 1
MOLYBDENUM 90 87
NICKEL 1 0
MANGANESE 0 1
SILVER 0 0
TITANIUM 0 1
POTASSIUM 0 2
BORON 180 156
SILICON 6 6
SODIUM 17 13
CALCIUM 3010 3165
MAGNESIUM 16 21
PHOSPHORUS 928 905
ZINC 1178 1041
BARIUM 0 0
INSOLUBLES TR TR
WATER 0 0
FLASHPOINT ºF 335 420
SUS VIS 210ºF 71.4 68.1
cSt @ 212ºF 13.31 12.46
FUEL % 2.0
ANTIFREEZE % 0 0
[/quote]
Copper is usually from bearings, but I wouldn't worry about it, your copper and iron are right about at universal averages according to the specs that Blackstone gave at my last UOA for my 2000 Boxster.
When I bought my car used Boxster PO did 10k mile oil changes. First UOA showed very high iron, around 30 and slightly elevated copper. I did 3 short interval changes, around 1k miles each, to flush out the motor and now on an OCI of about 3-4k miles, iron and copper are down to 9 and 6.
Copper in a new engine is unlikely to be from bearings! Sheesh.
Assembly lubes, sealants, etc. May throw those numbers for a bit until you clear all that junk out of your new engine.
Good report.
Here's the screen shot from Blackstone.
I ask about copper because it's double the universal average. Not that it's a problem, just curious. This car has 23,000 miles and has had 5 oil changes, I would hope there is no leftover assembly lube or anything left in there!
29253d1364321850-second-oil-analysis-08-cayman-s-23-000-miles-08-porsche-031013_oilanalysis.jpg
Note that we run a fleet of trucks. I have had new GM v8's throw high copper numbers for at least three OCI's, so wait until you get a bit more mileage before the engine gets blamed.
Probably nuttin', like Chase said above even an oil cooler can have copper tubes in it that skew the results...
