Originally Posted By: SirTanon
I will mirror what Demarpaint has said. I added a little over 1/2 qt of MMO to my last oil change in my Sable (3.0 Duratec), along with 4.5 qt of 5w30 Valv. ML conv. Didn't have to top up, and I'm a little over 4k miles on it. I'll be changing the oil this weekend.
This is on about 95% highway driving @ 65-75MPH in Phoenix summer weather.
I will say this however, to the OP. MMO doesn't thicken your oil - it thins it, slightly. My car specs 5w20 oil, and so I used 5w30 as my oil fill. I remember reading somewhere that MMO is basically a 10 weight oil, so with my fill, I'm looking at a final weight of roughly 5.5w-28.
Glad you agree. IIRC the tech guy at Turtle wax said MMO was about a 5 grade oil. Either way I had no problems with it flashing off. If you check the UOA section you can see the impact it had on viscosity in real world use after however many miles it was in use. Using a viscosity calculator gives an approximate viscosity. The UOA shows how it held up and the viscosity at the end of the OCI, assuming the engine had no issues with fuel dilution.
Here's a UOA with 5W30 and MMO. http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3457991/1/3800_S3,_cleaning_experiment_M
