I never have and generally do not mix motor oils, but the lack of good deals and my ample oil stash has me thinking that I should just use what I've got for this next change.
If you guys had to select a 6-qt mix of oil from the following list, what would you choose? Application is an '08 Dodge 4.7 with Mobil 1 oil filter for an 8k OCI (2 months or so) in Northern/Central CA.
What I've got:
Mobil 1 Advanced Fuel Economy 0w20 - 5 qts
Mobil 1 5w20 - 4 qts
Penn. Ultra 5w20 - 1 qt
Mobil 1 Advanced Fuel Economy 0w30 - 2 qts
Penn. Ultra 5w30 - 3 qts
Mobil 1 5w30 - 1 qt
Mobil 1 5w30 HM - 2 qts
Mobil 1 0w40 - 16 qts
Mobil 1 Turbo Diesel Truck 5w40 - 9 qts
Mobil 1 15w50 - 8 qts
Amsoil 20w50 - 1 qt
I was actually just thinking of using 5 qts of the Mobil 1 0w20 and throwing in the Amoil 20w50 since it has been sitting around a few years...is this a bad idea? Should I stick with a 20wt or 30wt for all 6 quarts? Or does it not even matter?
What I've got:
Mobil 1 5w30 - 1 qt
Amsoil 20w50 - 1 qt
