OVERKILL
$100 Site Donor 2021
Originally Posted By: Triton_330
Originally Posted By: virginoil
Too many threads now advising against mixing oils even within the same brand.
nO nO AND No.
AT $100 AUD for 5L of Royal Purple in OZ why would one want do that other than play chemist.
Below is an internet net link where mixing of oils was discussed with Royal Purple Tech Teps for street bikes with a view to getting an improvement for the W number. It is not encouraged or recommended.
Evidence no engines have ever blown up is not A scientific reason validating the process It may sound good for the layman.
http://www.superstreetbike.com/how-to/engine-oil-viscosity-mythbusters
I absolutely disagree. While of course I know there is no such thing as "in-between grades" of oils, what I'm disagreeing to is that you shouldn't mix oils.
I say, mix away. Why? All API certified oils must be miscible/mixable in order to obtain, and retain API certification.
Playing chemist? So what. People run Frankenbrews all the time.
Where's CATERHAM when you need him? Of course he has his own special blend named after him, right here on BITOG.
Right now I'm running a mix of two oils in my mother's 96 Explorer. API certified oil is API certified oil. And, we don't run long OCI's anyways. We change around 5k miles or when the OLM pops on. I had some spare bottles of oil left over from previous changes, and her car takes 5 quarts. I mixed 2 quarts of Royal Purple 0w-20 and 3 quarts of Castrol GTX Synblend 5w30. We've had her Explorer for almost 15 years now. For a 1996 Explorer with over 180k miles, she does NOT burn any oil, and has never given us any problems besides it needing a new fuel pump last year, knock on wood.
Mixing brands and grades, so long as all are API certified, is totally fine. It might lower the potential for a longer OCI, but if you don't do long OCI's anyway, it isn't going to matter.
~ Triton
P.S.
Originally Posted By: wemay
Blackstone Labs says it's perfectly fine to mix as does Valvoline and others...
I don't consider Blackstone Labs etc. to be layman nor would I take a manufacturer's word too seriously who obviously wouldn't want you mix their oil brand with another. I have done it once and would do so again if needed but I PREFER to run 5 quarts of the same.
+1
I'm guessing you've missed the numerous posts on this from Shannow as well as this thread:
http://www.bobistheoilguy.com/forums/ubb...922#Post3503439
nO nO AND No.
~ Triton
P.S.
+1
