If its back at idle just do your gauge at rest . If you can set it up - do the cranking one out of AA11 - I have a more detailed list for that .
I think the shop is the way to go here - if nothing breaks loose before the weather - you have taken a pretty good run at it - I'm convinced one way or another you have more than 1-2 things going on .Then again you might catch it - and the FP/TECHRON ...ETC .
Its just amazing how fast you can go with the right scope etc esp. ignition and fuel .
If its a reasonable cost maybe they could straighten out your cap hardware while you are there .
I'd want to take a look at that 90k service receipt and make sure if the valve adjustment was done or not - just for my own understanding - it "might" have been "somewhat optional" .
What does the factory manual say on when to do after 90k ?Is it something like "listen" every 30k and do as needed ?
Anyway , cleaning sensors ,and running around doing any other good maintenance activity can't hurt and can only help .(Old lists/posts - still good for other troubleshooting/maintenance point of view) .
(You might want to make sure you have some dielectric grease and antiseize compound on your spark plugs) .
For the long haul if previously you used carburator cleaner on the TB AND scrubbed and rubbed a little hard then in the future be prepared to clean it more often - they originally had a nonstick coating that helps keep them clean .
If you had access to a tap and die set you could do what I call the "tokyo tune up" by cleaning up PT/chasis grounds .
Just about a year and a half a ago on another familly members Honda by cleaning up 16-17 grounds and replacing the ignition switch we were able to avoid replacing the SRS module ,ABS module ,Ignition coil/something or other? ,and a window regulator that was slow .
Two dealers and one independent shop all wanted to replace all the above when all it really needed were the grounds and a switch .These were reputable people and the independent was wondering and although everybody pulled out their diagnostic equipment they believed their gear and the "standard failure rates" on these items instead of thinking a little outside the box - ie what affects them all at the same time and is simple .19K later , I'm still feeling vindicated but it doesn't always go that way .
Whatever you and they do , put the VG on it when you get it back .
For on the road testing I usually use a secure tee fitting and run a secured (long) vacuum hose to the cabin( both ends clamped) .As far as routing to the cabin it depends - sometimes thru the cowl somehow - sometimes with the hood on second latch - and "roped" - some its better if left unspoken here .(You obviously don't want the hose pinched or falling off) .
I also use two people - its easy to pay too much attention to the gauge and not the road when things start happening .You really do want to write stuff down - short term/long term benefit .I'd do all this only after eliminating everything at idle - and if then still faced with only a "rolling miss" .
One thing I was curious about on your Sat am roadtest ; were you able to go thru 1/2 one time each w/o a miss of any kind ?
