Well , I took too long - missed the library .
Gary lets look at something that we seem to see or weigh differently .
Sunday , when jeff do his road testing , although he didn't get completely maxed he did get various WOT "runs" with a hill etc and he did get to 5000rpm in 5th . So my thought is that in consideration of all the rest the most likely interpretation is that his ignition considering the " electrical load" was working good enough and that injector drible/spray patterns/"problems" or even o ring problems of a certain type were being overcome by rpm , turbulence ,mixing , etc - and thats w/o assuming the other changes that typically accompany VTEC STAGE 2 operation .
A sure comfirmation of this is when the miss is occurring worst ; ie more load but not enough compensation factors what ever they really are in here . I'm saying this in a "weighting" kind of way - most likely - not certain .
There is more to this from over here but thats the main thing .
I don't really want to WAG guess this one but if I did I'd be "leaning" towards more than one thing .
Ignition issue and or combination of issues? - top contender for #2 position - thats partially based on a quick look at the 124tsbs on this car(lots of electrical) at the NHTSA and a deep look at the ignition switch recall (which if you go far enough into Honda's paperwork there includes the "ignition command module") , and those that didn't get a recall . I'm also keeping in mind his age and mileage -which is significant in terms of this ignition system in general - lots of failures of many kinds by 150k .
Well ,I'm going far afield here but bottom line ;
at high (enough - barely ) rpm , with mediumhigh load and mediumhigh throttle position this vehicle did not crossfire or if the ignition was "skipping" it wasn't much . The occassional miss there is much more consistent with at least one weak injector that can't occasionally be overcome - thats been one of the most consistent signs of fuel pressure or fuel injector problems all makes all models .
Its not of high relevance by any means but for instance , on the 1992 Accord I'm maintaining for a familly member the first thing the factory manual wants checked for a miss accompanied by a check engine light are the injectors .
