Quote:
tiny clues that throw you off the obvious.
Quote:
does this one have Coil Over Plug (COP) ?
if so, I HEARD (not experienced) that if you don't put the same COP back on the same cylinder, you can have issues....BUT, i don't see how or why.
I would yank the plugs and check the gap.
Quote:
I reset the codes when I read them. Drove it about 10 miles back from the auto parts store. The CEL did not come back on yet, but the misfiring was still apparent.
I believe the plugs are copper NGKs.
jeff
Quote:
First I'll answer all g20ooh's questions as best I can:
Quote:
greenjp ,
does the car run correctly above 3500rpm in any gear and regardless of load/throttle postion ?
Can you get to 3500rpm in 5th ,go to FULL WOT , get to 6000rpm with no detectable problems ?
Not quite. It definitely smooths out once you get to 3,500, but at WOT it stumbled a bit, and when doing this is when the CEL started blinking again and is now back on solid. Couldn't get it to 3,500 in 5th safely - too fast for the roads I was onIt definitely seemed to run smooth for the first minute of operation. It also runs ok with very light throttle positions at any rpm.![]()
Quote:
Did all of this start while still on the fuel you had in the tank before/at time of spark plug replacement ie did anybody buy any fuel just before this started up ?
Here's the sequence of events. New cap, rotor, spark plugs, and wires installed last fall. Everything ran fine. A couple weeks ago one of the plug wires started popping loose off the plug, resulting in poor running. They were el cheapo generics and I discovered that they were falling apart. I replaced them on Tuesday with the new NGK wires. Everything was good. On Thursday, the FP3000 showed up and I put in a double dose along with filling up the tank since the car hasn't had any sort of gas additive for a few months. On Friday I drove the car about 60 miles, then gave it an oil change. Drove the car some more on Friday and Saturday. My wife took the car out for a 180 mile drive on Sunday, and called me about 50 miles in complaining of the symptoms.
Quote:
If a quick but careful check of your cap,rotor,wires (and their installation ) shows aok do an accurate spark plug torque check . Do Not overtighten just make sure they are correct . Also look for a hairline crack of sorts on the cap/cap towers and the rotor itself . Since its so quick and easy to do - do check your wires resistence values .
All this seemed to check out. I don't have a voltmeter (need to get one of those) but visually the cap, rotor, wires, and plugs looked ok. I torqued the plugs too.
Quote:
What exactly was the difficulty when you replaced the cap/rotor previously ?
I replaced the cap and rotor last fall - in the process 2 of the bolts holding the cap to the distributor housing sheared off inside the distributor. One of those apparently common things that nobody mentions when you're planning the job! The cap is now held on by a stainless steel worm drive hose clamp - it's rock solid and has been fine for months.
Quote:
When was the last time/date you replaced the timing belt ?
It was replaced a couple of years ago, at 105k.
Quote:
1 ) I wouldn't do the O2 sensor before I had eliminated the miss .
2) You are probably going to want to replace that fuel filter one way or the other . When was it done last ?
O2 sensors look to run $150 or so, so I agree. Not sure when the fuel filter was replaced. Probably at the 90k service. I'll put on a new one as it's probably a good time for it regardless.![]()
Quote:
1)EGR -not enough to trip OBD2 EGR IN SOME CASES
The dude on the radio show I called this morning suggested the same thing - but I don't think the EX has an EGR valve! The Haynes manual indicates that only models with the D16Y5 engines have it - the EX is the D16Y8, and I couldn't find an EGR listed for the EX on any parts websites. If anyone knows otherwise, I'd love to be filled in.
Quote:
2)Bad fuel ,Fuel injectors/fuel pressure -filter
I'll be the happiest guy around if a fuel filter fixes it!
Quote:
3 )Ignition . Mostly worn plugs , some wires , lots of coils , and some igniter modules .
I believe the cap, rotor, wires, and plugs are all ok - none of those of course preclude something like coils or the distributor itself.
jeff
Quote:
Well, more like he got (cough-cough) lassoed and side tracked on an action packed adventure ..that had nothing to do with the problem nor was able to disclose it. (now on to step 164 ..but what about step 4)![]()
Quote:
BTW , as am sure you are aware , a fresh set of plugs can cover a multitude of other problems including primary ignition , grounds , and fuel air problems as well .
Quote:
Wouldn't you agree Gary , that checking the old plugs for everything from part# , condition , measured gap , and esp. any deposits present would be extremely useful here ?
Quote:
How can fresh plugs cover up a primary ignition problem or fuel/air problems?
Quote:
Gee , Gary , I just saw this reply .
WT ......![]()
My apologies -I hope I didn't offend you when mentioning just the biggest of your errors in this thread .![]()
I also didn't realise the possibility ...... are you by chance heavily invested in FP ?![]()
Using your kind of , um.... 'logic'? , I realise now its really special stuff .
(It must be , boy, talk about backing and filling and reframing reality ........)![]()
(You related by any chance , to anyone on this forum who drives a prius ?)
Just think of the 'unfortunate' 'coincidence' here , 110 miles ,maybe 3 - 4 gallons of fuel thru the motor and all 4 plugs crapped out .
Why its almost .... unbelievable ....![]()
Oh well , as they say timing - I mean coincidence is .... everything - in this case ...... ??? .
I mean ,we should just ignore that ..... just like you did for eight pages .... and esp. now , right ?![]()
One thing for certain ,I'm sure glad FPs in the clear here - I was becoming a bit uncomfortable .
The only time I've seen this kind of display .... or 'performance enhancement' or 'coincidence' was when somebody added incorrectly any number of things such as JPx , biodiesel , dino diesel, kerosene etc - maybe with a dash of somethin' else ......or.......just got some 'POL contaminated' fuel with much the same .
Pretty relevant here ..... exact same kind of outcome ...... its just so easy to get a bad batch ..... of fuel ......of course ..... - at least now I'm sure you know what I mean .
Thanks for straightening out the end here - I'm sure our younger , less experienced members are now better informed, - the sharper group at least - who can see beyond the trees and ...... shrubs .
Nice job.
Quote:
Jeff, how about eliminating that arcing effect during spray misting? I think we would all feel better having an explanation/cure for this before you get out the vaccum gauge again.
