Number_35
Here are the #5 and #6 spark plugs:
However, the problem turned out to be the timing belt. After removing the serpentine belt and the P/S pump bolts, the pump can be moved far enough (without removing the hydraulic hoses) to remove the upper TB cover on the inner (closer to the firewall) bank (Cylinders 1 to 3).
The timing belt is cracked and has a lot of slack in it. It's almost certain the hydraulic tensioner has failed. I would bet the belt, tensioner, WP, and idler pulley are all original.
It was around -11°C earlier, and I worked slowly, with lots of tool trips back to my house (5 houses away), combined with warm-up breaks for my hands.
I can't do this job properly working outside in the snow. I told my friend I can do the work in April or May when it warms up, or he can have it towed to a shop. (I can put it back together as-is, but the vehicle should not be driven - it's already skipped at least one tooth, and another skip might mean the end for this interference engine. As well, the misfires would damage the cat quickly.
